Weird grinding noise!
Old Feb 27, 2006 | 08:28 AM
99F-250lova's Avatar
99F-250lova
The past two days now I have noticed that when I am driving and I let my foot off the gas something starts grinding pretty loud. It only does it when I am going around 20mph and lower. To me it sounds like my gear box has absolutely no oil in it. Can you help??
Old Feb 27, 2006 | 08:39 AM
Kwikkordead's Avatar
Kwikkordead
Have you checked the fluid levels everywhere? If all is good then you're going to need to get all four wheels off the ground so they will spin. Run the motor in gear and get under the truck and start listening. A long screwdriver with the handle pressed against your ear makes an exellent stethescope. You can pinpoint the offending bearing very easily.
Old Feb 27, 2006 | 08:40 AM
99F-250lova
sorry, not gear box but front differential!! That is just what it sounds like but I don't know why it would just suddenly start happening because I know that there is no leak.
Old Feb 27, 2006 | 08:49 AM
Kwikkordead
I this while the 4X4 is engaged?
Old Feb 27, 2006 | 09:29 AM
99F-250lova
Do you think it could be a U joint?
Old Feb 27, 2006 | 09:50 AM
Kwikkordead
That depends. If you are in 4X4 then yes it's a consideration. If you are not using 4X4, then the front driveline is not rotating and you need to look at the front wheel bearings. Those big tires will beat up the front end a lot faster than someone with stock sized tires.
Old Feb 27, 2006 | 12:45 PM
bilder12's Avatar
bilder12
did ya pick up a stone and its laying against one of the rotors?
Old Feb 28, 2006 | 05:45 AM
99F-250lova
Well when I went home yesterday it didn't make the noise at all. I am thinking maybe it has to do with how cold it is outside or maybe I did pick up a stone. I will check it out when I get off work today. Can wheel bearings go out all of a sudden or is it gradual?
Old Feb 28, 2006 | 04:05 PM
bilder12's Avatar
bilder12
I 've never had a wheel bearing go out all at once like a light bulb ... but I dont know what you've been doing with the truck. Also, they dont heal and then go bad again ... once they go , they be gone.
mblanken881
Sep 24, 2013 06:25 PM
HumminFummins
17
Sep 16, 2013 08:40 AM
Flip4ford
Kansas Chapter
16
Mar 28, 2012 10:42 PM
wrestler003
2004 - 2008 F150
Feb 2, 2009 05:45 PM
sancochojoe
22
Jul 19, 2006 07:36 AM
