Grinding Right Before Stop
Old Sep 23, 2013 | 06:47 PM
mblanken881's Avatar
mblanken881
How to explain this?
I have something grinding when I come to a stop in my 05 F250 FX4 6 liter.
It only does it right before a stop. When I'm going say around five MPH it will make a grinding noise for a second or two then stop. It stops grinding before I am completely stopped. So hit five MPH, grind for a second or two, stop grinding while I complete stopping.
You know how the truck kind of revs up for a second right before stopping. That's when it does it. And only then.
I never hear or feel anything any other time. I can hit the brakes hard at 50 MPH and nothing. Only right before I stop.
Any ideas?
Old Sep 23, 2013 | 06:53 PM
djanzen's Avatar
djanzen
Check you rear brakes! Ill bet you have a stuck calliper, seen this lots!
Old Sep 23, 2013 | 08:13 PM
mblanken881
That reminds me...
I've had the ABS light coming and going recently. AE shows left rear sensor code. Could this have anything to do with it?
Old Sep 23, 2013 | 08:41 PM
BLADE35's Avatar
BLADE35
Me Too
And Just did a Set two days ago I had to Grind the Metal Shoe Part the Pad Mounts too
I end up messing with every set some so they FLoat Free and avoid Stick
A Dremal Tool is almost a Must
Old Sep 23, 2013 | 09:00 PM
djanzen's Avatar
djanzen
Originally Posted by BLADE35
Me Too
And Anitsieze High temp!
Old Sep 23, 2013 | 09:03 PM
djanzen's Avatar
djanzen
Originally Posted by mblanken881
That reminds me...
take a flashlight and crawl under the truck and look between the guard and the calliper at the rotor. I don't know why they do this but most of the time it is the inner pad that is worn off.
Old Sep 23, 2013 | 09:08 PM
djanzen's Avatar
djanzen
Here read this
https://www.ford-trucks.com/forums/1...-calipers.html
Old Sep 24, 2013 | 08:09 AM
mblanken881
I will look once it stops raining here.
Just curious though...if one of the rear calipers is sticking then why would it only grind for that very short period of time?
Old Sep 24, 2013 | 06:05 PM
djanzen's Avatar
djanzen
I don't know the answer to that! But it happens a lot!
Old Sep 24, 2013 | 06:25 PM
BLADE35's Avatar
BLADE35
Hell Ya
Iv been buying that Brake stuff in the little Packets each time
I have High temp antiseize I use on Every Nut and Bolt just about
Don't know why I didn't think to use it on the Brakes too I will Now
732t37
Jan 19, 2012 10:50 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Jul 22, 2008 10:44 PM
thenewjohndeere
1978 - 1996 Big Bronco
Oct 21, 2006 01:19 PM
subnet76
Mar 13, 2006 10:37 PM
dusterwise
Jul 20, 2003 10:09 PM
