Oil In Engine Valley
Old Feb 15, 2009 | 03:42 PM
Automator's Avatar
Automator
I looked in the engine valley today and there was a small puddle to the rear of the engine. What could be the source of this puddle?
Old Feb 15, 2009 | 03:52 PM
big poppa's Avatar
big poppa
Turbo O-rings i would say Dave, i had a puddle there too and it was my o-rings. Clean it up in there and have a look after a short drive to make sure.
Old Feb 15, 2009 | 04:11 PM
Automator's Avatar
Automator
Well, I was going to putting in the WW soon anyway. Guess this will move it up.
Old Feb 15, 2009 | 04:22 PM
big poppa's Avatar
big poppa
Sounds like a plan. Can't help you much on the pulling of the turbo, did my WW with the turbo on and the o-rings were under warranty when they leaked but it seems like a straight foward operation, good luck to yaa.
Old Feb 15, 2009 | 05:02 PM
StanleyZ's Avatar
StanleyZ
On mine it's the cac tubes. Big orange tubes with screw clamps on them. I re-tighten mine every oil change and it works. Need a socket I think 7mm and a 6 inch or longer extension to get on the camp screws. Climb on top and look down into the rear of the tubes. Tighten the clamps and suck out the oil from the valley and see if it returns. If the clamps don't have any slack then i guess it's something more. serious
Old Feb 15, 2009 | 05:20 PM
Automator's Avatar
Automator
Guess I go to Guzzle's O-Ring site and get them, looks like $8 for his set. Anything else you recommend while I'm there and spending money?
Old Feb 15, 2009 | 06:14 PM
jdecker88's Avatar
jdecker88
I would order a turbo reintstall kit and HPOP O-rings while your at it. The turbo reinstall kit is pretty nice. Since you already have a fumoto valve.
Old Feb 15, 2009 | 06:44 PM
F350-6's Avatar
F350-6
If it's just a small puddle, there's also a chance it's a leaking actuator rod on the EBPV. Those have been known to drip a little oil in the winter time.
Old Feb 15, 2009 | 07:13 PM
zack7.3's Avatar
zack7.3
Mine leaks a little here. So I just unplugged the wire and now no leaks. It is on my list to fix, but here in El Paso the EBPV is not that big a deal because it dosen't get very cold here.
Old Feb 15, 2009 | 08:01 PM
steelers06steelers's Avatar
steelers06steelers
Had the same problem, it was the EBPV, the problem is mine is a manual transmission, the oil puddle was able to run down thru the drain hole in the intake manifold directly onto the clutch disk, caused my clutch to slip, so if you have a manual trans. take care of it!!!!
You can have the turbo off in about 2-3 hours. Not to bad....
Old Feb 16, 2009 | 04:18 PM
Automator's Avatar
Automator
I may have one of the guys at work here look it over, he used to be a Ford mechanic and has his own business on the side. My schedule looks too full to get a chance to look at it myself.
BTW: Go Steelers
Rose88racing
Jan 14, 2019 10:10 AM
wolff7.3
13
Jul 19, 2016 06:18 PM
Edogsf350
Jul 12, 2014 05:41 PM
Hkp30
Jan 16, 2012 02:18 PM
fridgeddiesel
36
Jan 3, 2009 08:40 PM
