52 Ford f1
Old Feb 15, 2009 | 08:39 AM
stonemanfrank's Avatar
stonemanfrank
52 Ford f1
Hello, I'm thinking to 4x4 my truck, anyone done this? what frame would be best and easy? The previous owner butchered the stock frame so it's got to come out, just looking for some suggestions.
Thanks,
Frank
Old Feb 15, 2009 | 09:03 AM
havi's Avatar
havi
I'll have the Roast Duck
I've seen Ford rangers under the F1's 48-52 before, and the fit is pretty close. Not as beefy as a full size 4x4 though. And welcome to FTE!
Old Feb 15, 2009 | 09:35 AM
stonemanfrank
Thanks for the welcome, finally decided to do something with this truck. Also heard about the s10 frame, any info on that swap.
Old Feb 15, 2009 | 10:26 AM
bobj49f2's Avatar
bobj49f2
Welcome to the board.
This is the post you have to read:
https://www.ford-trucks.com/forums/7...d-f-1-4x4.html
Hopefully John,jpb222, will drop in and offer his incite. Check out John's other posts for more on his truck.
One thing, please post your location in the upper right corner of the box. You can do it in one of the links in your control panel. It's nice to know where someone is located. It helps if you're asking for help or parts, if we know where you are there may be someone close by who can help. Also, if you're looking for a part and someone has it, most likely they'd more willing to offer it if they know it won't cost an arm and leg to send it if you're close by.
Old Feb 15, 2009 | 12:16 PM
Julies Cool F1's Avatar
Julies Cool F1
HI Welcome to FTE.
There's a few guys who have done this and lots of info stored here.
One of the nice things about the site is all the posts get stored like a library so you can go back and look up everything.
To do that, you look in the upper right hand corner and you will see "Search This Forum" just type in 4x4 and all the related threads will come up!
Have fun
Old Feb 15, 2009 | 02:05 PM
bobj49f2's Avatar
bobj49f2
Julie, I think at this point he has too few post to access the search feature, I think you need a minimum of 25.
Old Feb 23, 2009 | 08:06 AM
stonemanfrank
Frame question
Found a 51 3/4 ton frame, is it the same as the 52 f1?
Aaron-71
Oct 12, 2011 11:34 AM
thedieselkid
Feb 17, 2010 10:35 AM
skymonkey
May 7, 2007 08:25 AM
oldmansimek
Nov 6, 2006 09:28 AM
njtinman2
Feb 8, 2005 12:16 PM
