Sponsored by: Real Truck
are frames the same for 2wd 4wd??
Old Feb 16, 2010 | 08:41 PM
thedieselkid's Avatar
thedieselkid
my frame maybe bent on my 99 4x4 i found a good deal on a frame but its off a 2wd truck. Will it work??
Old Feb 16, 2010 | 08:51 PM
I.B. Washincars's Avatar
I.B. Washincars
car-part.com does not differentiate between 2 or 4WD. It looks like a single year item. When searching for a 99 frame only 99 comes up as a replacement.
Old Feb 16, 2010 | 09:52 PM
QwkTrip's Avatar
QwkTrip
I'm not entirely sure, but I think people that do 4x4 conversions have to fabricate brackets. That suggest the front frames are not the same.
Old Feb 17, 2010 | 07:34 AM
RedJeepProjectYJ's Avatar
RedJeepProjectYJ
You would have to do slight mods to make it work. 1999-2004 F250/350 4X4 Trucks are leaf sprung in the front and rear, and the 2wd trucks have Coil springs. So you would deff. have to add leaf spring mounts and trac bar mounts for sure. Not to much work if you can get one for a deal and can weld.
Old Feb 17, 2010 | 10:21 AM
brian42's Avatar
brian42
Veteran: Navy
I don't know about the frame itself (although I would think that from a practical, cost-effective production standpoint the frame would be common for all configurations to make it easy for assembly and replacement parts), but the 2wd setup in front for the axle is different. The solid front axle for the 4x4 is replaced by a solid beam that the steering knuckles attach to. Also the ride height is a little lower in front for a 2wd and the steering links are different (although they attach to the pitman arm and steering knuckles the same way). As for the rest, I'm not sure.
Old Feb 17, 2010 | 10:35 AM
cartmanea's Avatar
cartmanea
How badly is it bent? Take it to a shop with a frame machine and they can check it and possibly straighten it. Mine's been straightened twice now.
Sugarmommaracing
Sep 18, 2011 10:32 AM
iceman320
Nov 23, 2010 10:51 PM
FORDS-FOREVER
Apr 8, 2008 05:54 PM
78ford351m
Jul 20, 2006 11:14 PM
big79ford
Mar 17, 2004 11:11 PM
