General Automotive Discussion
Does anyone have an engine air compressor?
Old Feb 13, 2009 | 08:13 PM
therifleman556's Avatar
therifleman556
I have an idea for a useful farm truck. It would utilize an older pickup(more room under hood) that would have semi truck air tanks mounted on the frame somewhere and would be charged by an engine mounted air compressor that I salvaged off of a mid '70s 366 Chev that had air brakes. All that would need to be done would to make a mounting bracket and run coolant and oil lines to and from the compressor. Has anyone tried this? Suggestions? Thanks...
Old Feb 14, 2009 | 04:09 AM
cjben's Avatar
cjben
I don't know any one that has done that,but you can turn certain types of a/c compressors into air compressors to fill your air tanks. Look in the off road forum for on board air and there should be some ideas on how to do it.
Old Feb 14, 2009 | 03:01 PM
fordboy_52's Avatar
fordboy_52
it has been done on service trucks and what-not. usually they are driven off of a pto rather than the engine directly. remember, full air tanks can be dangerous in a wreck
Old Feb 14, 2009 | 03:09 PM
Ford_Six's Avatar
Ford_Six
The old York a/c compressors are much more suited to this, since they have their own oil supply, and a clutch on the front. Hook the clutch to a pressure switch, and you have a fully automatic system. If you do use the truck compressor, make sure you properly hook up the governor. That compressor is spinning all the time, and the governor simply holds the intake valves open so it doesn't pump air when not needed. If it's not properly hooked up and set, then it can just keep pumping air until it blows something up.
shameless
34
Oct 4, 2016 09:26 PM
Jsgilliam
Sep 14, 2013 06:22 AM
nibiru
13
Jan 3, 2011 11:49 PM
zavierbr
Feb 16, 2009 11:19 AM
blindlightguy
Mar 8, 2008 10:14 AM
