Air filter thinking correct?
Old Feb 13, 2009 | 04:05 PM
Phrosut's Avatar
Phrosut
Times are tight and as much as I'd like to buy the Ford AIS intake system, it's out of the budget for the foreseeable future. I have a 4" turbo-back exhaust and the Evolution II for tunes so now I am trying to address the intake options. WITHOUT spending hundreds.
Because the Ford AIS seems to work better when people install a foam 'boot' and cut a hole in the housing to allow air in from the inner fender, it sounds like the 'snorkel' tube from the box to the grille doesn't pass as much air as the engine would like. The stock 'snorkel' looks to be smaller.
Would/should my intake volume be helped immensely if I did two relatively inexpensive things? First: cut a hole in my stock box and install the boot to draw air from the inner fender and Second: buy and install AFE's #73-80006 filter, which is the Pro-Guard element but in a larger conical shape that fits into the stock airbox.
Also, can anybody tell me the difference between AFE's two filter recharge kits, Gold or Blue, and therefore which I'd need if I don't learn of a compelling reason to NOT do this little mod?
Phil
Old Feb 13, 2009 | 04:14 PM
HKusp's Avatar
HKusp
Bro, if you are worrying about spending money and want performance out of your truck, scrap that idea and look at the link in my signature. Scroll down until you see the 6637 mod. It will perform nearly as well as the AFE and the AIS and it is HUNDREDS cheaper.
Old Feb 13, 2009 | 04:15 PM
randomhero1172's Avatar
randomhero1172
Whats wrong with the 6637 intake mod? do u know what it is? also - the stock air filter setup is good for up to like 500 or more HP. the only thing a air filter will do is A- lower EGTS just a touch and B- help filtration (this isnt a proven fact but some say the stock box lets alot of dust in)
Id say skip the AIS ford intake and do the 6637. Will cost alot less and will improve filtration and air flow.
Old Feb 13, 2009 | 04:16 PM
randomhero1172
Damn you jason haha. Your too quick
Old Feb 13, 2009 | 04:22 PM
HKusp's Avatar
HKusp
Sorry Joe.
Old Feb 13, 2009 | 04:27 PM
Phrosut's Avatar
Phrosut
Thanks J, and you too J!
I've given a lot of thought and read posts here for months. Only two things holding me back from the 6637 mod:
It doesn't look 'stock' (a minor fetish of mine)
Most members here have mentioned that it's LOUDER and I'd rather keep the noise level as low as possible
And lowering my EGTs would be the first reason I am looking at modifying the intake with any increase in available power second.
Phil
Old Feb 13, 2009 | 04:30 PM
Phrosut's Avatar
Phrosut
This AFE filter is less than $70 too, so the 6637 mod isn't all that much less expensive. Phil
Old Feb 13, 2009 | 04:34 PM
HKusp's Avatar
HKusp
$28-$32 delivered from fleetfilter.com vs. $70 adds up over the next couple of times that you have to replace the filter, but if you have a dislike for the added noise it may be worth it to you to go another route.
Old Feb 13, 2009 | 04:36 PM
HH60FE's Avatar
HH60FE
Phil, the 6637 was the FIRST thing I did, and it isn't louder, all I get is the woooosh sound when letting off the throttle, which I love. Try it, you'll like it!
Old Feb 13, 2009 | 04:39 PM
megawatt00's Avatar
megawatt00
Here is a pic of my 6637,,
A little food for thought.
Old Feb 13, 2009 | 04:45 PM
Phrosut's Avatar
Phrosut
The "Pro-Guard" is touted to be as good in filtration as a good standard filter but it is reusable, LIKE a K&N but without the problems according to AFE's website. Of course, without members here endorsing AFE's products I'd be less inclined to believe their claims.
Phil
Old Feb 13, 2009 | 04:49 PM
Phrosut's Avatar
Phrosut
Matt, I'm encouraged by your "...isn't louder..." statement. And Jim, your install is VERY nicely done but I'm guessing we're talking about "hundreds" again? Phil
Old Feb 13, 2009 | 04:58 PM
megawatt00's Avatar
megawatt00
Nope the box I built out of scrap sheetmetal. Other than the filter the paint was the most costly thing. My fault for going with metallic paint.
Old Feb 13, 2009 | 05:06 PM
Phrosut's Avatar
Phrosut
WOW Jim!! I had to go back and check on your location.... FL and/or MA are too far for me to inspect/copy/share some beverages. I'm VERY impressed with your job and you've added another option I hadn't considered. Do you have any more pics? That looks like some standard rubber door trim on the upper edge? Your solution would bring in cool air from the front and the fender plus maybe reduce any noise.
Phil
Old Feb 13, 2009 | 05:12 PM
megawatt00's Avatar
megawatt00
Thanks Phil. Some day I want to make up a few more and sell them. Too much going on now so no time. Here is a link to my photobucket there are a binch of pics there.
Cold Air Intake pictures by megawatt00 - Photobucket
