Clutch Replacement
Old Feb 15, 2009 | 11:00 AM
TOW II's Avatar
TOW II
Our local garage said they'd do the clutch replacement for $250 labor. I think we’ll go that route, then tackle the brakes next weekend. I think they’re going to need everything; rotors, calipers…
Old Feb 15, 2009 | 11:45 AM
Pablo-UA's Avatar
Pablo-UA
i work on trucks, but I really hate to drop tranny. I prefere to change wiring harness ore fix someones' engine ECU.... and let change clutch to someone else.
Old Feb 15, 2009 | 11:56 AM
TOW II's Avatar
TOW II
I'm with you on that!! I can think of at least 4 clutches that I've done, and each time I swear that it will be the last time. fficeffice" /><O></O>
When I was younger I had a motto ‘never pay someone to do something that you can do yourself’. After I turned 50, I reversed that motto. <O></O>
Old Feb 15, 2009 | 04:07 PM
monckywrench's Avatar
monckywrench
If you farm out the clutch job, ensure the flywheel is resurfaced if needed.
"After I turned 50, I reversed that motto."
I just score more tools to make jobs easier, and the cash I save makes that a paying proposition. (Never lift manually what you can lift with machinery, in this case a floor jack is sufficient. ) By all means pay someone if you wish (mechanics need to eat too!) but on the scale of manual transmissions the Ranger is easy work and a good training opportunity if teaching someone else.
Old Feb 15, 2009 | 04:41 PM
Pablo-UA's Avatar
Pablo-UA
to work on aero tranny is easier, becouse you can unscrew 2 upper bolts from cabine. To uncrew these bolts under ranger is more difficult. Anyway it is much easier then to drop semitrucktor tranny...
wpnaes
Aug 11, 2017 01:20 PM
06FUN
Oct 29, 2016 07:53 AM
Thomas White
Jul 11, 2015 01:25 PM
Blackdog 15
1978 - 1996 Big Bronco
Dec 23, 2014 07:02 PM
59203shop
Oct 8, 2013 03:21 PM
