Bronco II Ford Bronco II
harmonica balancer removal
Old Feb 12, 2009 | 09:19 PM
89 bronco II's Avatar
89 bronco II
i have a 89 2.9L V6 in a bronco ii. can anyone tell me how to get the harmonica balancer off? i have removed the pulley and the bolt that holds the balancer to the crank. i have tried the usual balancer puller which doesn't seem to work. it seems to be working against it's self. when i look in the ford manual is says remove the center bolt and take the balancer off. no such luck there. so that's where i'm at. what am i missing or doing wrong? thanks
Old Feb 13, 2009 | 12:22 AM
kernel-panic's Avatar
kernel-panic
If you have removed all the bolts and there is nothing visible holding the balancer to the crank, then a puller should remove it. It may be a little difficult to remove (believe me, I have seen balancers and other things take quite a bit of persuasion to free up). You may wish to soak things in PB blaster or WD-40 and tap it lightly to allow it to work in to where the crank and balancer join, and then try the puller. Should be using a 3-finger jaw-type with the center bolt - and I believe there is an adapter for the center of the crankshaft, but I can't remember off the top of my head. Hope this helps.
poffutt
1978 - 1996 Big Bronco
Dec 19, 2008 06:57 PM
F250Dave
Sep 30, 2008 03:00 AM
bfd04
Bronco II
Sep 28, 2004 05:32 PM
urif250
May 31, 2002 08:15 AM
blackokc
Nov 19, 2001 09:10 PM
