Jranra
Old Feb 12, 2009 | 12:53 PM
JRANRA's Avatar
JRANRA
Jranra
MY CHECK ENGINE LIGHT CAME ON. I TOOK THE TRUCK TO AAMCO TO GET THE CODES THEY FOUND 1,3,5,7, GLOW PLUGS FAILUAR. I REPLACED ALL 8 AND THE LIGHT IS STILL ON. CAN YOU HELP
Old Feb 12, 2009 | 01:16 PM
ukmat71's Avatar
ukmat71
is it possible to reset it ?
i know on my old scooby you just had to join two plugs , the ecu would then reset & clear all fault codes, unplug the wires and fingers crossed no more fault codes.
i will have a look to see if i can find any info on resetting the brains of an EX
Old Feb 12, 2009 | 01:21 PM
ukmat71's Avatar
ukmat71
from what i have just found you just disconnect the negative wire to the battery for a while.
some have said to press the brake peddle while battery is disconnected.
Old Feb 12, 2009 | 03:52 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Your glow plug control module is bad. There is no way a whole bank of glowplugs decide to go bad at once. (although it may be possible).
If you look on the passenger side of your engine, there is a silver box with a green and black plug going into. That's where the problem lies. Go on ebay or to the Ford or International dealer and they can get you a new one.
Be advised, you'll find the same part on ebay a hell of a lot cheaper than if you went to the dealer.
Old Feb 12, 2009 | 09:58 PM
Immortal_Ben's Avatar
Immortal_Ben
Sorry, but that really made me laugh.
wendal
Jun 10, 2017 11:35 PM
gdkaufman
Nov 18, 2016 04:15 PM
Philster
Sep 25, 2016 10:45 AM
53pickemuptruck
May 27, 2016 11:06 AM
Amish Ford
Sep 7, 2015 05:46 PM
