Headlight on no tail lights
Old Nov 18, 2016 | 09:32 AM
gdkaufman's Avatar
gdkaufman
I turn on my headlights and all other lights DO NOT come on, no tail lights , no dash lights no marker lights, if I put light switch in parking light position there are no lights on. BUT somewhere between headlight position and parking light position I can get the parking light to come on. Plus the dome light flickers.
Old Nov 18, 2016 | 09:37 AM
Binkowski's Avatar
Binkowski
Well, start with the basics by checking for any blown fuses. Your owners manual will tell you where and which ones to check. Can't tell you since you don't tell us what vehicle you are talking about.
Sounds like your headlight switch is bad. The switch is known for aging and going bad. Not hard to replace, just need to remove the dash cover and swap out the switch. As with any electrical work though, disconnect the battery so you don't short things out and cause more problems.
Old Nov 18, 2016 | 09:43 AM
gdkaufman's Avatar
gdkaufman
this is a 1995 f150 ext cab flair side w/5.8. I have replaced the light switch and did not help.
Old Nov 18, 2016 | 10:02 AM
subford's Avatar
subford
Sounds like fuse #10 is open.
Old Nov 18, 2016 | 04:15 PM
gdkaufman's Avatar
gdkaufman
Found the problem, fuse #4 missed it yesterday upper left of fuse box, hard to see. Everything is working great once again, thanks for your help.
Bmamer196
Jan 20, 2018 09:12 AM
mctim64
Nov 6, 2012 05:14 PM
1994F2507.3L
Oct 3, 2011 10:21 AM
walnut777
Aug 15, 2008 11:10 AM
FordPickup460
Nov 21, 2004 12:51 PM
