Problems with 90 ranger
Old Feb 12, 2009 | 12:15 PM
gerendfs's Avatar
gerendfs
I posted this in the wrong section earlier and was directed to (I think) up here. I apologize if this is also the wrong place :P
I have a 90 ford ranger. I believe it's a V6 4 liter. It's not a diesel truck. I have 2 issues that I'm not sure if they are related:
1) Anytime it's cold I have to warm my truck up until the temperature gauge hits the normal range. If I try and drive before it's warm, the truck will stall out when I try and accelerate from a stop. It will usually start back up, but only if I hit the gas, and if I try and shift back into gear it will die again. So I usually have to restart and rev the engine for a few minutes to get it warm. Once it's warm it won't stall out anymore.
2) After the truck is warm it will begin to make a loud rattling or clanking sound. It kind of sounds like a diesel engine. It only happens when in drive and at 2000-2500 RPMS. The rate of the noise changes as the engine accelerates.
I've recently replaced the fuel filter, heater core, and flushed the radiator/cooling system.
Anyone have any ideas what might be causing these 2 problems?
Old Feb 12, 2009 | 06:49 PM
1st4x4 beach truck's Avatar
1st4x4 beach truck
how many miles are on the truck? it kinda sounds like a rod baring or two. my buddie had a mustang that had a bad rod baring, it only nocked under a load.
Old Feb 13, 2009 | 04:37 AM
wendell borror's Avatar
wendell borror
As far as the first problem, it sounds like the cold start injector is bad, it sorta works like a choke on a carb, it riches the fuel until the engine is warm. Valvetrain chatter could be wrong fuel mixture to oil pump going bad or pluged oil gally. Try running a can of seafoam through it to clean up carbon deposites and what not and hope for the best.
Old Feb 14, 2009 | 04:44 PM
BSmitty's Avatar
BSmitty
Is the noise under load of while "loafing" at those rpms? I'd guess you have a bad sensor somewhere and it's throwing your mixture off. Start by having the codes pulled or buying a $30 code reader at wally world. If there is a sensor out of range you may have a code, even if the CEL isn't on.
Old Feb 16, 2009 | 08:33 AM
gerendfs's Avatar
gerendfs
The truck has 85k miles on it. I get the rattling while driving normally. I'm not towing anything.
I'll see if I can pickup a code reader and check for any codes. I may also grab my camcorder and record the rattling.
LARIAT 85
May 12, 2009 04:28 PM
rat49f6
Apr 4, 2009 09:22 AM
fordxlt150
19
Mar 16, 2009 10:55 PM
owned
20
Apr 3, 2008 10:32 AM
Edigan
Apr 1, 2008 10:43 AM
