Crankcase/PCV Tube
Old Feb 13, 2009 | 04:33 PM
MikeyHasARanger's Avatar
MikeyHasARanger
Crankcase/PCV Tube
Howdy,
I have a 2003 Ranger 4x4, 4.0L. I just took it in for oil change and diagnostic. I was told that my Crankcase/PCV tube is broken. Does anyone have pictures or a diagram of where this is located? Any help would be great.
Thanks.
Old Feb 14, 2009 | 09:17 AM
Redranger03's Avatar
Redranger03
I just checked my Alldata, shows no listing for PVC valve or PCV tube.
Old Feb 14, 2009 | 02:19 PM
drb1956's Avatar
drb1956
IF, and a BIG IF, your 4.0L does have a PCV valve, as I can't find a listing anywhere, but my '91-'99 Chiltons for my Ranger shows the PCV valve in the left rear valve cover, with a tube going to the intake manifold on that side..Take a look see and let us know what you find......
Old Feb 14, 2009 | 06:29 PM
michigan66's Avatar
michigan66
Y2K Ford Discount Parts (an FTE sponsor) lists a PCV hose for a 2003 Ranger with a 4.0 L engine, so the part exists. Sorry though, I can't tell you where the part is located.
Old Feb 16, 2009 | 08:39 AM
griz4718's Avatar
griz4718
Look at the firewall side of the valve cover on the drivers side. The PCV valve is located there. It has a large tube in the center and a smaller tube "wrapped" around it for coolant. The larger tube goes behind the engine to the passengers side then goes toward the front of the engine ending with a 90 degree turn into the intake manifold. Find out what part of the tube is broken as on my truck (2003 with 4.0) the rubber 90 degree fitting at the intake manifold was split wide open. Picked up a shaped piece of heater hose that worked just great and is stronger than the part I took off.
Are you throwing any codes, check engine light on???
eallanboggs
2004 - 2008 F150
Dec 20, 2021 06:09 PM
WB4IUY
Escape & Escape Hybrid
Jun 28, 2014 10:50 AM
hav24wheel
Apr 17, 2010 04:38 PM
eallanboggs
1997 - 2003 F150
Jan 23, 2010 11:29 PM
bseberle
Feb 18, 2005 05:32 PM
