Problems with 90 Ranger
I have a 90 ford ranger. I believe it's a V6 4 liter. It's not a diesel truck. I have 2 issues that I'm not sure if they are related:
1) Anytime it's cold I have to warm my truck up until the temperature gauge hits the normal range. If I try and drive before it's warm, the truck will stall out when I try and accelerate from a stop. It will usually start back up, but only if I hit the gas, and if I try and shift back into gear it will die again. So I usually have to restart and rev the engine for a few minutes to get it warm. Once it's warm it won't stall out anymore.
2) After the truck is warm it will begin to make a loud rattling or clanking sound. It kind of sounds like a diesel engine. It only happens when in drive and at 2000-2500 RPMS. The rate of the noise changes as the engine accelerates.
I've recently replaced the fuel filter, heater core, and flushed the radiator/cooling system.
Anyone have any ideas what might be causing these 2 problems?
However if I was to guess I would say your engine is being over fueled. Probably a defective fuel pressure regulator but you would need a fuel pressure test to be certain. The noise you hear may be due to the engine running bad and possibly defective transmission or engine mounts. Hope this helps.
