2.9 Ranger Engine won't start
Old Feb 11, 2009 | 08:28 PM
Lobo33's Avatar
Lobo33
After replacing distributor cap, rotor, spark plug and wire's we started the engine. After a couple minutes the engine stalled and we have not been able to get it started again. We know that were getting spark to the sparkplugs and we even tried a little ether but no luck. Any suggestions will be tried.
Thanks
Kel
Old Feb 12, 2009 | 07:27 AM
pawpaw's Avatar
pawpaw
Sounds like you may be resurrecting a vintage ride here.
Was it running ok before the work?????
How is the fuel pressure????
If it's not right, pull the vacuum line to the fuel pressure regulator on the fuel rail & check for fuel in it's vacuum line, if you find any, suspect it's diaphragm is bad & replace the FPR.
If you think the FPR is ok, check the fuel filter, it could be clogged.
If thats ok, back up to the fuel pump/s & make sure their working & the lines are clear.
How is the fuel quality???
You say it has spark, but is it a good blue/hot spark, that has "snap"????
If not, check system grounds & the battery voltage under load.
Some thoughts for pondering. Let us know what you find.
Old Feb 12, 2009 | 08:33 AM
84bronc2's Avatar
84bronc2
if its been a sittin awhile you could drop the gas tank or siphen out the gas if it is old gas because alot of times it is hard to start or wont start at all if there is old gas in it i know it sounds like it could be to simple to be the problem but it could be or see if your fuel filter is plugged or see if you are even getting gas up to the motor good luck!
Old Feb 12, 2009 | 09:11 AM
Lobo33's Avatar
Lobo33
86 Ranger 2.9 engine
In response to whether it ran before the replacement of the plugs, cap, rotor and wires, the answer is it hadn't run as the battery was dead and it was decided to give it a minor tune up before we tried starting it. We have syphomed out the tank and replaced it with new gas also.
still trying..........
Old Feb 12, 2009 | 10:47 AM
84bronc2's Avatar
84bronc2
do you have gas getting up to the motor? also it might be a coil that is throwing to weak of a spark good luck
gastley
Escape & Escape Hybrid
May 14, 2014 11:59 AM
davegr1
1978 - 1996 Big Bronco
Oct 28, 2012 01:07 PM
IMonCRACK
Jun 16, 2012 09:27 PM
shad0w4life
Jan 12, 2004 08:18 PM
