EOT Mod ?
Old Feb 11, 2009 | 08:24 PM
97biostroke's Avatar
97biostroke
EOT Mod ?
I decided I'd give the ol eot mod a try, so I went and got some resistors and a potentiometer to keep my options open. What resistance would you all recommend? Its going to be on a switch for those cold mornings when the oil's already nice'n'chilly. And before I go cutting wires, exactly which sensor am i splicing into? I know its in the front of the motor, just not sure exactly where. Any help would be great.
Old Feb 11, 2009 | 10:40 PM
c00nhunterjoe's Avatar
c00nhunterjoe
4.7k, no potentiomemter. the switch probably wont work, and its not needed,
Old Feb 11, 2009 | 11:01 PM
97biostroke
Alright thanks for the pics/info Joe Ill get that wired up here soon.
Old Feb 11, 2009 | 11:47 PM
BlueMule's Avatar
BlueMule
Be careful running the EOT mod with an auto trans. The PCM does not monitor trans fluid temperature but it does use the info from the EOT to determine when to lock the torque convertor. If the PCM thinks that the engine oil is not up to operating temperature it also assumes that the transmission is cold and keeps the torque convertor unlocked to build up additional heat.
Old Feb 12, 2009 | 07:33 AM
MADVAN's Avatar
MADVAN
This seems to change with pcm codes.
The pcm does use the EOT/TFT/Baro for the trans.
The no tc lock cold was nothing more than ford protecting
themself from tc issues from thick dino and low EPC.
The no lock cold sch is a POS.
Bill
Old Feb 12, 2009 | 09:52 AM
97biostroke
I'll keep a close eye out when running the mod. I usually watch the rpms when i get up to speed in the morning to make sure its locked up. If it starts acting funny I'll just take it. I might get some gauges here soon to so I can keep an eye on temps.
Old Feb 12, 2009 | 10:28 AM
BlueMule's Avatar
BlueMule
Bill
TFT
Old Feb 12, 2009 | 10:34 AM
cowmilker08's Avatar
cowmilker08
transmission fluid temperature
Old Feb 12, 2009 | 11:02 AM
MADVAN's Avatar
MADVAN
Correct.
The no cold tc lock even effects motor warmup time.
It warms quicker with TC Locking vs non locking. Confirmed will realtime scans
and egt's.
Bill
Old Feb 12, 2009 | 06:42 PM
c00nhunterjoe
the mod has noo effect on my tc lock up timing even on sub zero days. takes the same amount of time and miles driven to get the first engaement of the day with and without the mod in place
Old Feb 12, 2009 | 07:08 PM
BlueMule's Avatar
BlueMule
How does the PCM know the TFT?
Old Feb 12, 2009 | 07:12 PM
Action4478's Avatar
Action4478
I Know for sure you can fool the PCM....(On TFT) ..If you try ....
Old Feb 12, 2009 | 07:21 PM
tjbeggs's Avatar
tjbeggs
TFT sensor in the Valve body
Old Feb 12, 2009 | 07:22 PM
Action4478's Avatar
Action4478
Is it possible your mod isn't working( as expected) ?
the PCM knows what it is expecting ...
Are you also altering TFT ?...
how Are you benefiting from the mod ?
MADVAN's Avatar
MADVAN
Joe
Start the truck and let it run for 10mins then drive away.
Get the results of the tc locking. It should change.
With 10mins of idle time you get very little rise in the TFT and EOT.
Bill
