Aftermarket Products
Sponsored by: Worksport
Hood edge wind deflector question
Old Nov 4, 2002 | 01:46 PM
TallPaul's Avatar
TallPaul
My '95 F150 had a wind deflector on the hood leading edge, but it was grinding off paint so I chucked it. Soon as I did I started getting stone chips. Someone said the deflectors will prevent most stone chips. I have since had two chips and the latest one is taking out the windshield. Before I replace the windshield, I want to get a new deflector, but need to know where to get one that won't rub the hood. Anyone know of a deflector that stands a good inch or so off the hood? Also, my '84 F150 didn't seem to have the stone chip problem. I wonder if the more aerodynamic '95 is more conducive to stone chipping because of the airflow patterns.
INLINE SIX POWER! '95 F150 XL
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
Old Nov 4, 2002 | 07:17 PM
AlM's Avatar
AlM
yo paul,
We had an "EGR" model on our 96 bronco. It cleared the hood ok, but:
it did rub-off a very small bit of the plastic chrome on the upper edge of the grille (about 1/2 in wide and 1/4 in high)
when others got to close the hood, they would tend to grab the deflector and break off a plastic retainer clip. This got so bad that I had to remove the deflector although heavy clear packing tape would mend the break(s).
http://www.egrinc.com/EGRInc/FINDAPRODUCT.htm
Old Nov 4, 2002 | 07:30 PM
bronco351's Avatar
bronco351
I just bought a deflector for my 90 bronco. The deflector came with little rubber sticky things that stick to yur paint so the deflector doesn't rub against your truck. they come off really easy just pull them off!!!
Old Nov 5, 2002 | 06:25 AM
TallPaul's Avatar
TallPaul
I recall there were some little round marks on the hood, presumably from the little round sticky things that must have fallen off. I got the truck at 58,000 miles and the deflector already was on it.
The EGR model sounds like it would work. A little rubbing on the grille is not a problem for me. I think I need to go to a retail outlet where I can hold the deflector in place to see how it sits. This does not seem like a good item to mail order.
Old Nov 5, 2002 | 10:41 AM
chuckman's Avatar
chuckman
Have an old Deflect-Shield(? ill go check later) thats been on the truck since it was about a year old. hasnt worn anything off, at least not noticibly. IIRC, it has little rubber "gaskets" around the screws to keep the hood from rusting. Actually, the best exterior aftermarket piece on that truck thats been there a significant amount of time. Those things sure do save a lot of wiper fluid, hehehe.
Old Nov 5, 2002 | 05:08 PM
steve83's Avatar
steve83
I'd get the AutoVentshade Bugflector II. The #1 doesn't have the wraparound wings that cover the fenders. It sits very close to the paint, and comes with the sticky pads (that you can get at RadioShack), but the heavy curvature also makes it more rigid than the straight-up types. It won't flex as much when you're doing 90.
Old Nov 6, 2002 | 08:50 AM
TallPaul's Avatar
TallPaul
Wow. Just got my windshield replaced ('95 F150) for $155 installed! And it is NOT a used windshield. What a deal. The owner of the shop showed me the hood deflector on his '94 F150 (300 I6) and it stands well off the hood. He told me where I can get one and it is near my house. So I am on my way this afternoon for a deflector. Thanks for the help/comments. Also the owner of the glass place noted that the deflector does help deter stone chips, especially on Ford trucks. Now my wife's Aerostar has twice as big of a windshield and in 7 years we never got a stone chip. Must be something about the aerodynamics.
Old Nov 6, 2002 | 01:20 PM
Mil1ion's Avatar
Mil1ion
Paul,
Upper Right hand corner of this page.
Click "Accessories"
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 6, 2002 | 01:43 PM
TallPaul's Avatar
TallPaul
I see five brands are available, but it never says whether I will have a problem with it rubbing the hood. Perhaps the Bugflector II may work since it says it is easy to clean and wax hood which makes me think it is up off the hood. I'll have to think about it, maybe call AutoVentshade and ask them about the fit.
BTW I never looked at the Late Model Accessory store because to me Late Model means the new '97 and up style. Maybe you need to add a definition of late model.
Thanks.
Old Nov 7, 2002 | 11:03 AM
TallPaul's Avatar
TallPaul
So I went to the store and checked these bug deflectors (apparent correct term) out. Guy has one called the Stampeed for $55 which he says is made by the guy who used to make the Lund Interceptor and tha the cheaper Stampeed is basically the same thing. But then we are discussion wrap around versus regular shield and he asks what I am trying to protect. I said I really didn't care about the hood (I can slap some POR-15 on if it rusts) but want to avoid stone chips in the windshield. He says it only stops stones from straight in front and many come from the side and won't be stopped. So now I wonder if I should even bother with the deflector. Take my chances as the price of a windshield is only 155 (I called another local shop and they wanted 216 so looks like I got a pretty good deal). Anyway, I am in a holding pattern, not sure what to do.
Old Nov 8, 2002 | 06:25 PM
AlM's Avatar
AlM
yo,
Pull it and go bare!
With all the b Day and Christmas gifts, our 96 Bronco was in the beginning stage of becoming a ricer. I've taken all that plastic crap off and gone full metal...lol
Old Nov 10, 2002 | 02:13 AM
Bluehawk's Avatar
Bluehawk
I have the Lund Interceptor bug deflector on mine. It stays up about 1 - 1 1/2"off the hood.
Bluehawk
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4318&.jpg
F-250 SD XLT CC 4x4 Shortbed; 285/75R16 BFGoodrich T/A KO, MAAP nerf bars, Rally/Lightbar combo, PIAA 1300 driving lights, Lund bugshield, Lund SunVisor, tinted windows, K&N airfilter, Access tonneau cover, Rhino Liner, remote starter/security system, custom built console, Cobra 29 ST/WX CB with a Wilson 1000 magnet mount antenna, Realistic 500 channel police scanner, Kenwood 10 disk CD changer, Compaq laptop, SVP 100 Watt siren, and 24 Strobe lights.
Upgrades for the near future include: Warn Rio Grande pushbar with a 12,000# winch, 4" lift kit, and fender flares.
Old Nov 17, 2002 | 08:39 PM
theonlybull's Avatar
theonlybull
one came on my wife's ranger, and it viberated like crazy.... after 5 years of searching, i took it off one day to wax, and left it off for some strange reason..... never went back on... heck i'd give it away, if someone would just take it
Old Nov 17, 2002 | 10:29 PM
gavin_smith_1999's Avatar
gavin_smith_1999
Ruckus
2004 - 2008 F150
21
Mar 25, 2010 08:01 PM
pat2345
Apr 28, 2009 08:49 PM
shortystx
Appearance & Dress-Up
Mar 14, 2009 06:46 PM
dclarson
1997 - 2003 F150
Aug 13, 2002 02:09 PM
