installed wrong coil
Old Feb 11, 2009 | 10:03 AM
dogguira's Avatar
dogguira
A week or two ago I went to carquest and bought a coil for a 74 f100 390 no power anything. I got home and put it on the truck. Everything fine until Sunday, when the truck wouldn't start.
This morning I am rechecking wires for a short or blown fusible. I double checked my coil and saw that I given one with an internal ballastor. I know these trucks have a resistor. Could that have caused the problem?
Old Feb 11, 2009 | 11:02 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Key on. Check for voltage on + side to verify power to coil, check - side, no voltage = open coil. Need to put proper coil in anyway.
Old Feb 11, 2009 | 12:26 PM
dogguira's Avatar
dogguira
I just came in from the garage. My fusible link looks fine, insulation is not weak, hard, burnt, or discolored. I'll put my original coil back on and get a new one this weekend.
I have power to solenoid, starter, regulater, and the coil.
Old Feb 11, 2009 | 12:44 PM
JD IN NJ's Avatar
JD IN NJ
I think you have points check under dist. cap if they are burnt or if they are opening
Old Feb 11, 2009 | 03:05 PM
dogguira's Avatar
dogguira
Before this coil mess started, I changed the plugs and wires. They were so worn the metal in the wire head stayed with the spark plug. Then I replaced the rotor, condenser, and points.
The points worried me. The engine refused to crank if the points were gapped at all. I figured the system wasn't getting enough juice and replaced the coil.
Old Feb 11, 2009 | 03:11 PM
dogguira's Avatar
dogguira
The points still look all right. So far the truck has a new regulator, solenoid, battery, cables (including new ground), distributor cap, rotor, condenser, plugs and plug wires.
All the electrical wires look pretty good no cracks or burns. After I verified this I rewrapped them.
So now I am wondering what else I might be missing.
Old Feb 11, 2009 | 06:48 PM
Franklin2's Avatar
Franklin2
Get a testlight and hook it to the negative of the coil, and the other end to ground on the engine block. Crank the engine. If the light blinks when the engine turns, you are ok. If it doesn't something is wrong with the points, or the wiring to the points, or the ground wire inside the distributor.
Old Feb 12, 2009 | 08:15 AM
JD IN NJ's Avatar
JD IN NJ
Yea light will come on when points are open, off when closed.Take cap off and bump engine until rubbing block of points is on cam lobe of dist. Adjust points to .017 opening. Make sure feeler gauge is clean and has a slight drag when pulling across points.
Old Feb 12, 2009 | 06:34 PM
dogguira's Avatar
dogguira
Thanks I'll try this Saturday after I put in my new radiator.
Old Feb 14, 2009 | 03:56 PM
dogguira's Avatar
dogguira
Well I put in the new radiator. I tried changing the distributor ground, nothing. I then changed out the alternator, it started. That long bolt was a bugbear.
The weird thing is the battery never lost power. I was always told if the alternator was bad the battery would die.
Thanks for all of the help.
ciamcoop
Jul 11, 2016 07:51 PM
Maltman
Sep 12, 2013 12:24 PM
abe
Jan 1, 2013 04:51 PM
r2000f150
Apr 17, 2011 10:27 AM
roguebronco36
1978 - 1996 Big Bronco
Dec 29, 2001 01:56 AM
