1978 - 1996 Big Bronco
coil spacers
Old Apr 20, 2001 | 07:22 AM
roguebronco36's Avatar
roguebronco36
coil spacers
I have a 91 Bronco XLT and I was wondering if coil spacers are made for my coil springs?
Old Apr 22, 2001 | 11:03 PM
Bob_VT's Avatar
Bob_VT
coil spacers
Sure they are made but, if you add a spacer to lift the front end you will limit the amount of spring compression and feel as if you are bottoming out. They could create a slamming situation that is very tough on your front end. Want a higher front end by just an inch or two? Go with a variable rate heavy duty coil spring. I use them on my older (78) Bronco which is equipped with a snow plow and the work great. Or .... go with a full lift kit that comes with springs and brackets.
Old May 1, 2001 | 07:37 PM
xavetarx's Avatar
xavetarx
coil spacers
Do you have the spacers? If so, where did you get them? I already have a big lift, but want to go higher. I'm thinking of relocating the coil towers, but maybe the spacers would do the trick too?
Thanks,
-bob-
Old May 3, 2001 | 10:53 AM
roguebronco36
coil spacers
No, i dont have the spacers yet, i was just wanting to know if they were made so i could put some on my truck. sorry.
Old Nov 30, 2001 | 02:41 PM
CrmScntst's Avatar
CrmScntst
coil spacers
Old Dec 26, 2001 | 09:12 PM
SkorpioN's Avatar
SkorpioN
Post coil spacers
I just ordered some for my 92' F-150 4x4 for about $100.00. I have'nt got them yet but I'll post a message when I get them installed.
Old Dec 27, 2001 | 09:59 AM
adelyser's Avatar
adelyser
coil spacers
Keep in mind that if you lift the front via new coils or spacers, you will throw off the camber. Most lift kits contain the new brackets for the axle pivots to correct the camber. This is a $160 - $200 procedure at most tire places.
Aaron D.
Old Dec 29, 2001 | 01:56 AM
aflashman's Avatar
aflashman
coil spacers
>places.
>Aaron D.
So if you lift your bronco 2" with new springs you need to have it aligned(Camber Adjusted)?? Or do you need new brackets????
Thanks,
aflashman
mykdee
32
Oct 11, 2021 02:51 PM
76Chateau
Nov 15, 2013 08:12 PM
CourierYVR
Aerostar
Jul 22, 2013 12:08 AM
savageford
Jan 5, 2010 08:19 PM
MemOrex
Jul 12, 2009 06:49 PM
