1999 F150 Issues
Old Feb 7, 2009 | 02:59 PM
chump963's Avatar
chump963
Question 1999 F150 Issues
I just wanted to say im new to the site. And im looking forward to some help. I am looking into buying a used 1999 F150. The only thing holding me back is that the lights dim and go back to normal/flicker constantly. when you turn the headlights on and then back off. I mean all the interior lights Instrumental cluster, radio, dome light, etc. What i know of the alternator was replaced and check before install. The battery was replaced. We put a different headlight switch in and didnt help. Im running out of ideas I came here looking for some help. Any suggestions?
Old Feb 7, 2009 | 05:33 PM
Franklin2's Avatar
Franklin2
1. Did the problem happen after the new alternator install? Sometimes you inherit different problems while trying to solve others. And it won't be the first time people have installed "rebuilt" faulty parts.
2. If the problem was there before and after the new alternator install, I would check the grounds. What I would do is bolt a wire onto the alternator case, and run it over to the negative terminal of the battery, and see if the problem goes away. You don't see the flickering lights problem much on the newer trucks, but it happens all the time on the older trucks with the separate regulator, and running a ground wire under one of the reg mounting bolts over to the battery fixes it most every time.
Old Feb 7, 2009 | 11:44 PM
chump963's Avatar
chump963
We checked all the grounds. and it was there before and after we change the alternator. it does it mainly at idle.
Old Feb 7, 2009 | 11:58 PM
Franklin2's Avatar
Franklin2
If the alternator is mounted in a aluminum bracket, I would be suspicious it may be corroded and not giving a good connection at the mounting points. A simple test would be to take a jumper cable and clamp it to the alternator case, and clamp the other end to the battery negative post.
Old Feb 14, 2009 | 05:00 PM
chump963's Avatar
chump963
OK. i bought the truck. from driving it around in town. the volt meter shows thats charging is more then half(normal). But not on high. What would cause a over charge. like i said the alternator was test and tested fine by its self but was not test all the way through the charging system at the battery.
Old Feb 14, 2009 | 07:02 PM
chump963's Avatar
chump963
found out at idles at 15vs and higher rpms. but its wierd went on a 20 min drive and 60mph the volt meter was almost tapped out. so again what ALL can make it over charge.
Old Feb 14, 2009 | 10:15 PM
Franklin2's Avatar
Franklin2
Check the connectors on the alternator. Make sure they are not melted, and the connectors are making good contact. Also go into the fuse box under the hood, and check fuse #11. Pull it out and stick it back in to make sure it's making good contact. Also find the starter relay (passenger side corner of the firewall on a 4.6) and check all the connections on it. I would disconnect the battery +, and take all the wires off the starter relay and check them and then re-install them.
If the alternator checked out good, it has to be a connection problem somewhere.
dennis112
Dec 4, 2021 01:00 AM
Redmonkeynut
Aug 1, 2021 07:02 PM
elishaman
Dec 29, 2015 02:54 PM
tbugher62
Dec 16, 2013 07:21 AM
BadDogKuzz
87
Dec 19, 2012 11:04 AM
