Sponsored by: Real Truck
Headlight swap
Old Feb 10, 2009 | 04:09 PM
ameinig's Avatar
ameinig
Headlight swap
I am replacing my ugly yellowed 1999 aero style headlight assemblies with the later model pre 2005 jeweled type. How are the assemblies removed? It looks like they "pop" out but I didn't want to break them if I don't have to.
Thanks in advance!
Old Feb 10, 2009 | 04:14 PM
ReAX's Avatar
ReAX
The 04 unclip at two points and pop out of the third. Here's when I did mine, http://sites.google.com/site/reax222...attredirects=0
Old Feb 10, 2009 | 04:21 PM
ameinig's Avatar
ameinig
Thanks! That is exactly what I was looking for. I would have broken them for sure.
Old Feb 10, 2009 | 06:20 PM
ameinig's Avatar
ameinig
ReAX, did you try to align your headlights yourself or did you pay someone to do it?
Old Feb 10, 2009 | 06:31 PM
ReAX's Avatar
ReAX
I have to track down a friend of my fathers to get the socket. The E5 torx bit to adjust the headlights is a bear to find locally, I hope to pick one up off the Matco Truck in the next couple of days.
The adjustment is only vertical, which is pretty easy. I think I had it figured at dropping the headlights about 40 milli-radians. I was bored one drive home decided to figure it out in radians. In any case, with a 25 yard range, I'm going to drop the low beam hot spot about a foot and half.
Old Feb 10, 2009 | 06:34 PM
ameinig's Avatar
ameinig
Weird, no horizontal adjustment? E5 torx, what is that? Not the same as a T5 torx I am assuming?
Thanks for the info!
Old Feb 10, 2009 | 07:42 PM
ReAX's Avatar
ReAX
I didn't see any horizontal, but they bolted in pretty close. I just need to bring it down a little.
E5 is a socket that can drive a T5 bit. It's the female torx. E= female and T are the male types.
Old Feb 11, 2009 | 01:40 PM
Beerstalker's Avatar
Beerstalker
I was able to find a regular socket that fit on the torx head good enough to adjust my lights, didn't need to buy the special socket.
Old Feb 11, 2009 | 02:05 PM
ReAX's Avatar
ReAX
It can also be done with a set of pliers, or so I've read. However, the right tool makes the job easier.
FishBoat
Jul 2, 2011 01:52 PM
Jrock909
Aftermarket Products
May 15, 2008 11:07 PM
HUNTER10
Mar 10, 2007 08:50 PM
Bgrossenbacher
Bronco II
Dec 10, 2003 03:38 PM
