Sponsored by: Real Truck
Locked or auto
Old Feb 11, 2009 | 01:09 PM
bohiaa's Avatar
bohiaa
Locked or auto
Ok Guys Please dont make me out to be dumber than I already am.
New to 4 X 4 and the used 2000 F250 didn't come with an owners manual
am I suppose to keep it in locked or auto ?
Thanks a million
Old Feb 11, 2009 | 01:18 PM
nick381970's Avatar
nick381970
mine i run in auto that way if i get in the mud just turn the switch
Old Feb 11, 2009 | 01:25 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thanks a million
Here is an owners manual. Just fill in the info. click here.
Leave the hubs in auto.
Old Feb 11, 2009 | 01:29 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
In "Auto" the hubs are not locked into the stub shaft, so the front axle does not spin when the truck drives. When the ESOF system is activated, a vacuum pulse locks the hubs into the shafts, so that the transfer case can power the front axle. When the system is turned off, a vacuum pulse unlocks the hubs. In "lock" the hubs are always locked in, the front axle always spins, but is only powered when the t-case is engaged by flipping the switch in the cab. The lock function is provided because the vacuum system is notorious for failing, so you can manually lock the hubs and be assured that the wheels are getting power in 4wd.
Old Feb 11, 2009 | 01:34 PM
superduty4x4's Avatar
superduty4x4
Great explanation Bryan.
Old Feb 11, 2009 | 02:55 PM
bohiaa's Avatar
bohiaa
WOW thx guys.... Bryan explaned it Very well and now I even have an owners manual...
Thanks again
Old Feb 11, 2009 | 03:20 PM
Downriver Thunder's Avatar
Downriver Thunder
That is if the POS system works.
cattlerancher
Nov 27, 2014 08:43 PM
tdwarburton
May 31, 2014 11:14 AM
n4bql01
Sep 17, 2010 04:59 PM
morrisob
Aug 10, 2010 08:47 PM
cpf0300
Modular V10 (6.8l)
51
Jan 16, 2007 09:36 AM
