Need Help W/ Headlight
Old Mar 10, 2007 | 01:07 PM
HUNTER10's Avatar
HUNTER10
Hello everyone! I really need some help. My headlight bulb keeps blowing on my passanger side due to moisture getting in it. I bought some sealant to reseal the headlight - only problem is I can't get the headlight off. How in the world do you take out the headlight assembly? All help is greatly appreciated. 01 F250 superduty PSD
Old Mar 10, 2007 | 03:34 PM
dmueller71's Avatar
dmueller71
there are clips that hold them in. There is what looks like a bent over tab. I think there are 2 and a screw on the bottom if I remember correctly. They should just pry straight up with a flat head screwdriver.
Old Mar 10, 2007 | 08:50 PM
dfuser's Avatar
dfuser
The bottom one is a PITA to remove. You may have to remove the Battery so you can use pliers to remove the pin from the back. The two on the top can be remove by pulling on the pins.
94f250man
57
Mar 29, 2018 03:41 PM
RangerDude17
Jan 26, 2014 03:30 PM
bfktwb4
Nov 28, 2009 12:50 PM
