Best Rust Remover?
Old Feb 10, 2009 | 04:27 AM
Dave7.3's Avatar
Dave7.3
Question Best Rust Remover?
Hey fellas,
I'm just stopping in to ask, which brand of rust remover would you recommend? I'm prying at some hood hinges on a 1961 F100 that I picked up and could use something to free them up a bit.
I'm used to fighting rust with a wire brush and a grinding wheel but I need a little something extra to free these hinges up. I've heard WD-40, PB'laster, and a few home brewed ideas but I want to know which would work best from your experience. Thanks in advance!
I can vouch for the spray on stuff believe it or not, my turbo that I sold not too long ago was cleaned up pretty well, but I can't remember which type of stuff was used!
-Dave
Old Feb 10, 2009 | 05:33 AM
EMD_DRIVER's Avatar
EMD_DRIVER
I've heard some very good things about Aero Kroil, but have never tried it. You have to order it direct...
KanoLabs.com
Old Feb 10, 2009 | 07:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
wd40 is a water displacing agent. that is what the wd in the name stands for.
PB BLASTER works very good.
Old Feb 10, 2009 | 08:54 AM
dakotajeep's Avatar
dakotajeep
True but it still works well......Water Displacement-40 (it took the inventors 40 tries to get it right).....
Old Feb 10, 2009 | 06:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
In my opinion, WD 40 is great for freeing up frozen locks that have ice in them.
PB Blaster rocks when you need to break loose rusted bolts.
If PB Blaster won't loosen it up, torch time.
Never tried the Kroil, but I here it is great also.
Old Feb 10, 2009 | 07:00 PM
rupejosh's Avatar
rupejosh
pb blaster is some good stuff
Old Feb 15, 2009 | 11:03 PM
RP27G8G's Avatar
RP27G8G
PB is the ONLY thing to use!! I've tried about everything and PB works the best.
Old Feb 15, 2009 | 11:37 PM
Dodge/Cummins's Avatar
Dodge/Cummins
PB Blaster is the best thing I've ever used for automotive/industrial/equipment use.
I've used Kroil A LOT for/in my Gun/Gunsmithing shop and it's great for certain things but it doesn't seem to do much to rust. Especially heavy rust.
It's an AWESOME penetrating oil though in the true sense of the term. I had a can of AeroKroil rupture so I poured it in a Rubbermaid/Tupperware container and it went THROUGH it! It didn't melt a hole or anything it actually went THROUGH it.
I also use it to clean high-velocity rifle bores. It seems to get under the copper fouling and help you remove it with the aid of JB Bore Paste.
Old Feb 16, 2009 | 07:37 AM
Dean88's Avatar
Dean88
I only know of two proven rust removers
1. Grinder with a wire brush
2. Cutting torch
Nah, I'm sure that there are some good removers out there, but here in Texas, we really don't worry about rust.
Old Feb 16, 2009 | 08:04 AM
fonefiddy's Avatar
fonefiddy
Kroil is about as good as it gets. It is not a rust remover. It's a penetrating oil. And it does just that, better than anything else on the market.
KanoLabs.com
The next best is Penetro 90 from Schaeffer Manufacturing Company
Schaeffer Penetro 90 Penetrating Oil for Removing Rusted Bolts
Old Feb 16, 2009 | 12:24 PM
84 f250 6.9's Avatar
84 f250 6.9
pb blaster ... its sold EVERYWHERE even big lots for lik 2-3 bucks a can
Old Feb 16, 2009 | 12:49 PM
Dean88's Avatar
Dean88
Oops, I just realized you were wanting a penetrating oil rust remover, I was thinking surface/body rust remover
I agree PB blaster works, but you need to let it soak for days for extremely rusted bolts
Also a 50/50 ATF Acetone mix has worked very well for me.
My grandfather claims that if you heat a bolt up pretty hot,then take a candle and smash it on it, the hot bolt sucks in wax and makes it easier to take off
Old Feb 16, 2009 | 01:52 PM
tjc transport
i ain't rite
i have used the parifin wax deal before, and it works pretty good. but it is easier to just spray it with pb 3 or 4 times before trying to remove it.
Old Feb 16, 2009 | 08:59 PM
Dave Sponaugle
Actually I had a very hard time not saying a sand blaster with Black Beauty loaded in the hopper.
But I was able to contain myself for 6 days with a little concentration.
kr98664
'80-'86 HOWTO's
Apr 23, 2026 10:35 AM
MSgtling
Oct 13, 2014 03:49 AM
wickware
Jun 14, 2010 07:18 AM
pipercub
Paint & Bodywork
Jul 2, 2004 10:23 AM
