Air Cleaners
Old Feb 9, 2009 | 09:52 PM
black n black's Avatar
black n black
Air Cleaners
Can an aftermarket aircleaner cause the turbo to fart more and can this cause other problems? Can the turbo veins start sticking if the turbo does this? Reason: I have installed two types of aftermarket filters the first on was from Banks. After reading about you shouldnt use an oiled filter due to the fact it could cause a dusting affect I put on the OEM for a while and then Amsoil came out with a new filter thru Enjin. Bought it,installed it.liked it,but now I have a lot of Turbo farting when I let off of the pedal hard. Also around 2250 rpm the engine seems to miss-fire or stuters only when the engine is hot. Checked EGR (installed new one) still getting it. Now I removed the aircleaner went back to OEM and I have yet had the problem......maybe havent gotten up to right temp. But could these filters be causing these problems. If anyone wants a Banks aircleaner (cheap) let me know.
Old Feb 9, 2009 | 10:54 PM
uofmgriz's Avatar
uofmgriz
I have a Jobe Performance Cold Air Intake. Mine does the same thing, and yes, it can cause damage to the turbo. My advice is do what I did...at first it was cool, but now I try everything I can to prevent it from happening. You can also get a turbo blow off valve that will exhaust the air to prevent the back pressure. They run around $650, but that's cheaper than a new turbo.
Old Feb 10, 2009 | 07:38 AM
69cj's Avatar
69cj
Leaving the stock filter on is also cheaper than a new turbo and you won't have to fight Ford if you do loose the turbo while under warranty.
Old Feb 10, 2009 | 01:45 PM
steelhead2's Avatar
steelhead2
thats it, my afe is coming off. are the stock ones still 100 bucks?.
Old Feb 10, 2009 | 04:19 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
and unless you making 500RWH or more stock filter is the best for the job. and no problems. dont replace it untill your filter minder starts to move.
and filters are 60$ on flebay. get the OEM ones the ones with blue core not the white ones....
Old Feb 10, 2009 | 08:30 PM
uofmgriz's Avatar
uofmgriz
I have my stock filter on a shelf in the garage, any takers?
rhino3
Aug 28, 2008 08:33 AM
1978fordf250
Offroad & 4x4
Dec 31, 2006 10:51 PM
1978fordf250
Jun 1, 2006 11:18 PM
martman429
Aug 9, 2005 12:37 PM
