Strut Leveling kit option???
Old Feb 12, 2009 | 10:34 AM
Catmonkey's Avatar
Catmonkey
You realize the strut and spring are an assembly. Unscrewing the strut bolt that holds the spring assmebly to the strut would be a dangerous undertaking. There's only so much room to remove the strut assembly. If it were longer, you might not be able to remove it from the vehicle. I wouldn't attempt this without a compressor.
Old Feb 12, 2009 | 02:04 PM
gui88ford's Avatar
gui88ford
yeah, i agree 100%
Old Feb 13, 2009 | 03:29 PM
dixiemudder04's Avatar
dixiemudder04
I thought that i was like a coil over. So in order to change out the shocks you'd have to take out the coil?
Old Feb 13, 2009 | 06:03 PM
Drizzt's Avatar
Drizzt
am i also to assume that the rancho shocks do not come with coils as well?
Old Feb 13, 2009 | 06:16 PM
Catmonkey's Avatar
Catmonkey
All replacement struts for these trucks are just that, a strut. The Bilstein and Rancho struts both work with the factory coils which you remove from the old strut and mount on the new strut.
Old Feb 13, 2009 | 07:35 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by dixiemudder04
Y couldnt you jack the truck up by the frame and take out the struts, then put the new ones in and let it back down. Then you wouldnt have to use a compressor right? Just use the weight of the truck.
that show Trucks on Spike TV did that on a 05 they were making into a Roush Clone (red single cab)
but it is very dangerous, and even those 2 morons on Trucks said it wasn't exactly a good idea.
much much safer to just pull the whole assembly and use a spring compressor. should be able to rent one with just a deposit from most parts stores
snorindad
May 8, 2013 08:51 PM
Djack04F150XL
2004 - 2008 F150
Sep 27, 2010 10:18 PM
LAPII
2004 - 2008 F150
15
Jan 26, 2009 10:18 AM
stanger_missle
Nebraska Chapter
Jan 24, 2009 08:39 PM
silver05fx4
2004 - 2008 F150
Mar 28, 2008 11:18 AM
