Lifting a 2WD (Question)
Old Feb 12, 2009 | 12:10 PM
Timrock14's Avatar
Timrock14
I recently lifted my 2 WD Super crew 2006 F150. I put a 6" Fabtech suspension on it and love it. I would however like to go higher. Ive talked to ppl around here that have said doing a body lift or spacers would be a bad idea due to the suspension. ANybody know anything about this?
thanks,
Tim
Statesboro, GA
Old Feb 13, 2009 | 09:48 PM
WhëëlMå1's Avatar
WhëëlMå1
Thread moved to appropriate forum
Old Feb 13, 2009 | 10:49 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
how is your rear end lifted?
Add-a-leaf or blocks?
For the Rear:
almost all the lift kit companies sell bigger lift blocks.
but if you already have lift blocks, then I'd suggest a 1.5" AAL.
For the Front:
alot of guys stack a 2.5" leveling kit spacer ontop of the coil-overs. This gives them enough room to clear 37"...and sometimes 38" tires.
But since you are starting out 1" shorter than a 4x4, I'd stick with trying to clear 36...maybe 37" tires.
another option would be to buy new shocks...but those things can get downright expensive and quick. A good set of Kings or Dirt Logics can sometimes cost more than the 6" lift kit itself
