I-6 exhaust
Old Jan 11, 2000 | 02:50 AM
Greg Davis
Guest
Posts: n/a
I-6 exhaust
I have a 1993 F-150 I-6 manual transmission and of course there isn't a lot of power there. I'm thinking I'll need a new exhaust system soon, and am wondering if there are any aftermarket exhausts that may give me a little extra HP for not a ton of bucks.
Old Jan 11, 2000 | 02:37 PM
fishmaster
Guest
Posts: n/a
I-6 exhaust
For about $170 you should be able to get a 2.5" cat-back with a free flow muffler. Dont go any larger than a 2.5" because there's not enough back pressure. Get a K&N if you dont already have one.
Old Jan 11, 2000 | 11:50 PM
micah's Avatar
micah
I-6 exhaust
Clifford Performance: cliffordperformance.com
sells headers.
Old Jan 12, 2000 | 08:36 PM
gary manasco
Guest
Posts: n/a
I-6 exhaust
clifford carries headers for about $170
summitt carries headman for about $120
Old Jan 13, 2000 | 10:44 PM
Masterblaster
Guest
Posts: n/a
I-6 exhaust
If you have the two cats in series, a cheap way to go based on a previous posting, is to drop your original muffler and insert a straight pipe. Keep the rest of your exhaust stock to the rear of the truck. It will be only slightly louder, due to the cats. It it is too loud for your taste, you can go back and substitute a high-performance muffler for the straight pipe insert. The straight pipe experiment cost me only a couple of hours and $15.
Old Jan 14, 2000 | 12:09 AM
Greg's Avatar
Greg
I-6 exhaust
Thanks for your help. That straight pipe sounds interesting, but may go for a K&N if I can find a web site.
Old Jan 14, 2000 | 12:08 PM
t ugboat
Guest
Posts: n/a
I-6 exhaust
i have a 300 i6 with a c6 tranny and am gona cut the cats off already decided not going to replace but i wana know what would happen if i were to run straight off the two pipes going into the cats and make a duel exhaust outa that but down the truck a ways increase to 2.5"straight pipes all the way back will that be enough backpressure
Old Jan 14, 2000 | 06:12 PM
bubba's Avatar
bubba
I-6 exhaust
I have an '87 F-150 4X4 LWB regular cab, w/ EFI 300-6 cyl., 4 spd. tranny and dual exhaust. I cut the factory exhaust off at the two manifold tubes like you mentioned, ran 2" pipes to clear the tranny crossmember, then stepped up to 2 1/2"X18" Thrush glasspacks, the exit end of the glasspacks came out even with the rear of the cab, w/ 2 1/2" pipes the rest of the way out the back. Helped power noticably and gas mileage somewhat (13.6 MPG). But I do alot of hauling and towing. Sounds great to me, one guy in town told me that I had a great sounding 302, but I didn't tell him any different.
Old Jan 15, 2000 | 02:21 AM
tugboat's Avatar
tugboat
I-6 exhaust
what are these thrush glass packs i live in michigan and the only two i have saw up here are cherry bombs and turbo tubes where can i get them
Old Jan 15, 2000 | 04:28 PM
Trail_Rider's Avatar
Trail_Rider
I-6 exhaust
Cherry Bombs are another brand name of glass packs. Basically glass packs are mufflers that are straight through - you can look straight through them. The muffling comes from fiberglass packing.
Old Jan 15, 2000 | 06:10 PM
tugboat's Avatar
tugboat
I-6 exhaust
i understand what a glass pack is but the cherry bomb and the turbo tubes are both glass packs and they sound way different and these people witht he thrush say theres sounds like a 302 i want that sound
Old Jan 15, 2000 | 10:42 PM
bubba's Avatar
bubba
I-6 exhaust
Tugboat, all I have on Thrush Performance is thier address and phone #'s. Hope this helps you out.
BUBBA
Thrush Performance
2401 West First Street
Tempe, AZ. 85281
(602) 894-0249
(602) 894-8340 fax
Old Jan 28, 2000 | 12:18 AM
CRITTERGITTER's Avatar
CRITTERGITTER
I-6 exhaust
I've got a 91 f-150 I-6 and cut out the stock muffler and welded in a 2 1/4" flowmaster and added a K&N aircleaner. Flowmaster recommended keeping the stock 2 1/4" pipes to maintain backpressure for lowend torque. I can sure feel the difference especially when towing. The truck isn't loud, just a nice mellow rumble.
Got my parts through Summit Catalog (about 100.00 bucks all together) and a muffler shop can weld the muffler in for about $30 if you don't have access to a welder.
Old Jan 29, 2000 | 10:53 AM
crueljon's Avatar
crueljon
I-6 exhaust
IVE BEEN TALKING ABOUT MODIFYING MY 300 6 WITH A 4BBL CARB, AND RUNNING AN IGNITION OTHER THAN THE STOCK TFI-IV, MY 86 HAS A SINGLE OUTLET TO THE EXHAUST ON THE MANIFOLD, I WAS WONDERING IF I COULD USE A LATER MODEL SPLIT MANIFOLD , OR IF THEIR IS EMMISIONS HEADERS WITH THE EGR TUBE ON THEM. BECAUSE I WAS CONSIDERING KEEPING THE EGR FOR INSPECTION PURPOSES. I WANT DUAL EXHAUST BAD.
SOME BODY ELSE HERE ASKED "IS THERE TURBO OR SUPERCHARGERS AVAILIBLE FOR THE 300 SIX?" WELL IS THERE?
JOHN
Old Feb 15, 2000 | 06:01 PM
colt41's Avatar
colt41
I-6 exhaust
6brau
Jul 26, 2013 09:28 PM
wb6anp
2004 - 2008 F150
Feb 22, 2009 01:44 PM
BobbyB
Jul 25, 2005 02:03 PM
SkorpioN
Exhaust Systems
Jan 27, 2002 12:12 AM
brettvanh
Oct 5, 2001 04:55 PM
