1995 Powerstroke NO computer???
Old Feb 8, 2009 | 06:13 PM
70Post455's Avatar
70Post455
I just looked at a 1995 F250 ext cab 4wd powerstroke pickup. The truck has been very well maintained and runs and drives good. The gentleman that owns the truck told me he had taken it in to a tranny shop to have the tranny looked at because it shifts hard. The guy at the tranny shop said it had been rebuilt with a new valve body and a shift kit that is why it shifts very firm. He then went to plug it in to his scan tool but they could not find anywhere to plug it in. I thought the 95's all had computer read out???
Thanks for any help on this.
Tom
Old Feb 8, 2009 | 06:32 PM
tjbeggs's Avatar
tjbeggs
My 95 had an OBDII port just to the driver side of the glove box at the bottom of the dash. If its not there, there is an OBDI port in the engine compartment.
Old Feb 9, 2009 | 03:19 PM
884x4broncoII's Avatar
884x4broncoII
are you sure its not an idi? wasent there both powerstrokes and idi's in 95? or was that 94? 96 is there year everything went to obdII some 95 psd's did have obdII ports though
Old Feb 9, 2009 | 04:19 PM
cowmilker08's Avatar
cowmilker08
could this be why my tranny shifts kinda hard? when i bought it the guy at the tranny shop said that it was set for 'moderate towing'.
Old Feb 9, 2009 | 05:15 PM
NWBronco's Avatar
NWBronco
'95 cali models had the OBD-II. If the port ain't in the cab, it's under the hood on the driver's side, TJ told you that one. It may have a red cap on it and labeled EEC-IV test port. The transmission is overdrive with the cancel button on the shifter? If it's there and intact, it'll flash if there's a code against the transmission. You can read the codes with a code reader on the test port. It may be a shift kit that got you bumping around. Good luck with it.
sr's ranger
1983 - 2012 Ranger & B-Series
Sep 8, 2012 07:07 AM
rknight29
20
Jan 16, 2011 08:24 AM
70Post455
Jan 15, 2009 07:48 PM
tomtrevino
1978 - 1996 Big Bronco
Jul 5, 2006 11:37 AM
blackened
Apr 21, 2006 08:43 PM
