351c, 2v or 4v?
Old Feb 8, 2009 | 02:05 PM
dave2180's Avatar
dave2180
351c, 2v or 4v?
Last year I bought a 1980 f150. The engine is a 351c that I was told came out of a 71' interceptor. How do I find out if I have 2v or 4v heads. I am also wanting to make some slight to medium modifications on it to increase horsepower and torque, what should I do?.
Old Feb 8, 2009 | 04:02 PM
grclark351's Avatar
grclark351
at each top corner of the heads you'll see a number cast in where the valve cover rounds off and the head stays square.
Old Feb 8, 2009 | 05:48 PM
dave2180's Avatar
dave2180
is it a serial #?
Old Feb 8, 2009 | 06:10 PM
85e150's Avatar
85e150
The casting number can tell you a bit about the part, compare to the list here. Note the 5th or 5th & 6th character is the only difference in some cases.
What manifold is on it? 2v or 4v? Look like a stocker?
Are you going to do a tear down, or just pile parts on it?
Old Feb 8, 2009 | 07:19 PM
drof46's Avatar
drof46
The number on the corner of the head is just a number to tell you if its 2v 4v.
Old Feb 8, 2009 | 07:39 PM
dave2180's Avatar
dave2180
It has the stock manifold. I am wanting to put on a high rise manifold, new headers and possibly a cam but not sure what to get on any of these. Any suggestions, (do note that this is a mud truck with 6'' lift and 33' swampers.)
Old Feb 8, 2009 | 07:43 PM
JBradley500's Avatar
JBradley500
it depends on if its a 2v or 4v. funnel web intake is a good high rise if you want to go that way.
Old Feb 8, 2009 | 09:15 PM
dave2180's Avatar
dave2180
how much do they run and where can I get one. I'm desperate man the next mud bog is coming up soon and I have got a few chevys to show up, any more suggestions?
Old Feb 8, 2009 | 09:34 PM
JBradley500
you'd have to search for a distributor for them i believe... or a used one. they come from australia.
Old Feb 8, 2009 | 09:38 PM
grclark351's Avatar
grclark351
so what is the number on the corners of the heads?
stock cast tron intake manifold, 2bbl or 4bbl?
what kind of carb?
Old Feb 9, 2009 | 06:36 PM
dave2180's Avatar
dave2180
it has a 4bbl carter afb carb, I will find the number tommorrow and post it.
66ford400
May 30, 2005 02:50 AM
pintoches
Mar 9, 2005 09:50 PM
Knucklebuster
Ford vs The Competition
22
Jul 14, 2003 03:22 PM
xyfalcon500
May 27, 2002 01:16 PM
Zs514rd
Aug 23, 2001 09:26 AM
