Will Intake work
Old Aug 21, 2001 | 05:56 PM
Zs514rd's Avatar
Zs514rd
Will Intake work
I just picked up a '72 351C 2V. It has a stock 4V intake and carb.
Will the 4V setup work on the 2V heads or will I have to change to a 2V setup.
Old Aug 21, 2001 | 10:44 PM
Franklin2's Avatar
Franklin2
Will Intake work
The ports don't match very well on a FORD 4v intake. But an edelbrock 4v intake made for 2v heads will work.
Old Aug 22, 2001 | 12:02 AM
bigjohhanson's Avatar
bigjohhanson
Will Intake work
franklin2 is correct. The difference between 2v and 4v matching up is totally different. What I did on my 351c 2v is purchased the edelbrock 351c 4v perfomer, dual-plane intake. You can get on on ebay for around $150.00
Custom 1980 F100 short bed with 351c
Old Aug 22, 2001 | 09:12 AM
bbtkd's Avatar
bbtkd
Will Intake work
A previous poster said that you need the Performer 351C 4V intake, but that is not what you want. That is designed to work with the 4V heads and would not perform well for you.
You need the "Performer 351-2V (non-EGR) #2750". This is directly from their web page. It accepts a 4V square flange carb, such as a Holley or Edelbrock but works with the 2V heads.
I am confused on one point though - you say that it is a 351C 2V engine, then you say it has a stock 4V intake and carb. Are you sure that it has 2V heads? It may be worth checking because if someone swapped on a 4V intake and carb, they may have swapped the heads also. If so then you do indeed need the 351C 4V intake.
Tom
(1973 Ranchero with 1972 351 CJ and front clip)
Old Aug 22, 2001 | 06:48 PM
Boss_358's Avatar
Boss_358
Will Intake work
Toms right with the intakes on the 2V and the 4V. I have both a 4V and a 2V cleveland and both of them have the intakes. The one says performer 2V and the other says performer 4V.
People who say it can't be done should not interrupt the person doing it.
Old Aug 23, 2001 | 09:26 AM
beartracks's Avatar
beartracks
Will Intake work
20015.4f350
Oct 15, 2014 08:34 PM
78REDFORD
38
May 17, 2008 10:14 PM
scooter1986
Apr 2, 2007 07:17 AM
tgregoire
15
May 3, 2002 10:46 AM
ol_blue
Apr 16, 2001 10:22 AM
