My '76 F250 4x4 daily driver has a 300 in it,the motor could use a rebuild,but runs really well.I decided to find another 300 and rebuild it and still be able to drive my truck.
I havn't tore down the replacement 300 yet because I have been noticing adds guy's have in the classified's sellig used 300's.most of the adds state that the 300 is a "short block" for early eighties truck's.
This has gotten me to wonder what I bought since it came out of a 1980
F150 4x4.
The 300 in my '76,I believe to be from the '70's.
Is there a difference?
All the 240/300 blocks are essentially the same until the EFI came along and then the difference is the fuel pump mount hole on the EFI is blocked.
Just found this on another site:
"Early '65 - '66 blocks used a smaller thrust bearing. If I were using a racing automatic transmission / high stall torque converter I would avoid these."
"Early blocks (pre mid 80s) also used front-loaded cam bearings; later ones used two front-loaded / two rear-loaded."
