300I6 block length differences
Old Feb 8, 2009 | 01:00 PM
sedly's Avatar
sedly
Question 300I6 block length differences
My '76 F250 4x4 daily driver has a 300 in it,the motor could use a rebuild,but runs really well.I decided to find another 300 and rebuild it and still be able to drive my truck.
I havn't tore down the replacement 300 yet because I have been noticing adds guy's have in the classified's sellig used 300's.most of the adds state that the 300 is a "short block" for early eighties truck's.
This has gotten me to wonder what I bought since it came out of a 1980
F150 4x4.
The 300 in my '76,I believe to be from the '70's.
Is there a difference?
Old Feb 8, 2009 | 02:29 PM
Harte3's Avatar
Harte3
All the 240/300 blocks are essentially the same until the EFI came along and then the difference is the fuel pump mount hole on the EFI is blocked.
Just found this on another site:
"Early '65 - '66 blocks used a smaller thrust bearing. If I were using a racing automatic transmission / high stall torque converter I would avoid these."
"Early blocks (pre mid 80s) also used front-loaded cam bearings; later ones used two front-loaded / two rear-loaded."
Old Feb 8, 2009 | 04:23 PM
srercrcr's Avatar
srercrcr
I think what they mean by Short Block is it is just the block (and maybe heads), nothing hanging on it.
Old Feb 8, 2009 | 05:49 PM
85e150's Avatar
85e150
Short Block: Block with all the rotating stuff, maybe the oilpan. No heads.
Long Block: Block as above, with heads, but probably no manifolds.
Manifolds don't need "rebuilding" as do blocks and heads, so it is assumed you are going to reuse your existing items. Ditto accessories.
300 blocks may have some differences as indicated above, but overall length and bell pattern are not among them.
Old Feb 9, 2009 | 03:34 PM
sedly's Avatar
sedly
Well that makes sense.Thank's for the info,it's a bit of a relief knowing I didn't waste my time pulling the motor and my money.
Old Feb 9, 2009 | 07:01 PM
flipklos's Avatar
flipklos
Short block consists of
Block
Crank
Pistons
Rods
Main and rod bearings are installed as are cam bearings(usualy).
Long block
Add head(s)
Cam, Lifters, Pushrods, Rockers
Oil pump
and somtimes..........water pump and oil p/u
trozei
40
Sep 12, 2020 09:22 PM
lpdcjr
Engine Swaps
Feb 14, 2016 12:58 PM
AbusedAmericanRust
Aug 16, 2015 03:08 PM
ShadeTreeWizard
Aug 25, 2013 06:33 PM
76f250highboys
May 17, 2010 11:42 PM
