Coolant
Old Apr 18, 2009 | 03:11 PM
joe blow's Avatar
joe blow
What up....IAFF Local 3688 in Ca here...........
I just did a coolant filter add-on....I lost a few ounces if that.
I have several sets of "hose" pliers that I used to use when I did heater core R&R's or any minor coolant service work.
The pliers usually have two flat surfaces to pinch the hose but not destroy it. They have a click type ratchet to get a good cinch on them....you can improvise and clamp the hose somehow.
Considering you are getting the main feed from the 3/4" heater hose on the RH side of the block....pinch both sides, cut, install "T" and hose clamp it.
The return is on the top hose of the degas bottle.....You'll get MINIMAL coolant from there......
I REALLY DON'T THINK YOU'LL LOSE ENOUGH TO NEED TO PURCHASE COOLANT....It is nice to have though
Good Luck
Old Apr 18, 2009 | 03:39 PM
juneau76's Avatar
juneau76
The main reason why most do this is to flush the system before installing the filter.
Originally Posted by bismic
add distilled water to degas bottle
Should this read radiator or degas bottle? It seems as though filling the degas wouldn't be enough for the system. Am I wrong in my thinking?
Old Apr 19, 2009 | 12:36 PM
joe blow's Avatar
joe blow
Absolutely correct. I'm not sure if h20sprayer gave any details like that
Old Apr 19, 2009 | 01:18 PM
H2oSprayer's Avatar
H2oSprayer
I went ahead and purchased a gallon just in case. Also, I figured that I would need to add a bit to replace what was needed to fill the extra hose and filter. I added probably 1/4 gallon of a 50/50 mix.
Old Apr 19, 2009 | 01:21 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
On my 2005, there is NO radiator cap....can ONLY add coolent thru the degas bottle.
Old Apr 19, 2009 | 01:25 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
When I installed mine, I removed only the degas bottle and cleaned it...it had a lot of sand in it...now I can see if it starts to get dirty again....Haven't had my filter on only about 300 miles....
Old Apr 19, 2009 | 01:34 PM
joe blow's Avatar
joe blow
Awesome. I just ordered two more Baldwin filters (non CAS). I can't wait to cut the first one open and see if it was worth the investment.
Old Apr 19, 2009 | 01:37 PM
H2oSprayer's Avatar
H2oSprayer
I hear ya, just another month and I plan on cutting mine open as well.
Old Apr 19, 2009 | 07:15 PM
juneau76's Avatar
juneau76
D'oh! I was holding my 3 week old trying to keep her from screaming at me while her mother and sister were away and I did the speak (or type) before you think. You're right, there is no radiator cap.
Old Apr 19, 2009 | 07:25 PM
ljutic ss's Avatar
ljutic ss
Originally Posted by 6LPSD
1. around here in western pa it is only available at the dealership, costs 17.00/gal
2. zerex can be used as long as it meets fords specs for the coolant system.
3. it should be ok to mix them both.
4. i recommend flushing the sys out, adding a coolant filtration system and refill with
50/50 ford spec coolant.
these engines have a known problem with casting sand issues plugging the egr cooler and the oil coolers in the engine, this is why i recommend flushing the system and adding a coolant filter from dieselsite.com.
Sounds like that ford dealer over charged you on the antifreeze. I picked up 4 gallon back in Sept. for $13.86 a gallon list was $15.
Old Apr 20, 2009 | 09:42 AM
jobguy's Avatar
jobguy
Coolant
Thanks for the help.
68bluebeast
Mar 8, 2015 08:48 PM
V10man
2004 - 2008 F150
Jul 9, 2012 07:06 AM
BrianA
3.8 & 4.2L V6
Jan 17, 2012 09:43 AM
98explorerltd
Dec 1, 2008 09:35 PM
troutman2
24
Dec 19, 2003 04:57 PM
