Serpentine Belt- Ford or aftermarket
Discounted genuine Ford parts for members off the actual Ford MSRP.
There's an EZ to use online catalog on Ed's website.
There are THREE different belts listed for 1999 and later Super Duty 7.3's.
on
IIRC, the belt routing image should be on top of your radiator support arm on the driver side between the end of the radiator and the driver side battery, facing up. Then again, it is a Ford applied sticket, so I guess yours may have either peeled or been otherwise removed. I was awfully glad to find it when I replaced my belt 3 weeks ago... very handy to have when you're facing the engine and trying to figure our the routing after the old one is off!
I bought mine at NAPA, been fine.
You may want to consider replacing the top radiator hose to one that is routed outside of the belt. Do 'em both at the same time. Do a search for the hose on here.
Make darn sure you have an illustration of how the belt goes back on!!!
I had a Gatorback in my old F-150 for years and it was great too...
Just my .02
Great ideas-- thank you to all.
Picked up 16 qts of Mobil 1/ diesel today at Maomart for $26 per 4 qts. My son actually works at a large diesel truck stop and even with his employee discount Maomart was less. Will be switching over to syn and then onto the lift-- exhaust--cold air -- and programmer.
Can't wait for some new gadgets...
TBird Larry
07-29-2014 01:50 AM
wtf
02-04-2003 05:45 PM
