trannys screwy
Old Feb 7, 2009 | 04:03 PM
heathrunkles's Avatar
heathrunkles
trannys screwy
e4od with 177,000 miles on it. Driving it last week it wouldn't go itno 3'rdfrom second to fourth- second at like 3,400 rpm's then tc lock and Od shift. Rest of the shifts where sloppy. next day was better only did it twice instead of all the time. Next day while in 4'th the tranny would jump to nuetral. If I cancelled the OD button it went into 3'rd then hit the button and back to 4'th. No CEL or OD button Flash. New fluid and filter and sonnax Shift Kit 2 months ago.
Any Idea's
Thanks Guys
Old Feb 7, 2009 | 05:00 PM
c00nhunterjoe's Avatar
c00nhunterjoe
could be as simple as a sticking valve, does the sonnax kit involve replacing the accumulator springs? i'd start there
Old Feb 7, 2009 | 06:25 PM
heathrunkles
No it reuses the springs but gives shims for tension and replaces the actual valve. I beleive the valves are grooved to allow fluid to leak past, kind like drilling the VB. Would that explain the drop into neutral?
Old Feb 7, 2009 | 08:21 PM
c00nhunterjoe
i'd start by dropping the body and check for sticky valves. if they feel good remove them and look for a burr or abnormal wear marks on the valve and in the body
Ford SD
Nov 22, 2016 04:49 PM
JoeyM
Oct 10, 2015 05:16 PM
mcdavidson
Oct 8, 2014 02:24 PM
RunRed
Aug 13, 2009 08:50 PM
padutch
Jun 4, 2002 07:41 AM
