Bouncing idle at start sometimes...
Old Feb 7, 2009 | 01:28 PM
SleeprLegend's Avatar
SleeprLegend
Last year the original battery died in my 1995 F150 XLT Supercab 5.0. This year the same problem of dead battery and bouncing idle on some starts returned. I have installed a rebuilt alternator, and things have gotten better, but the idle will still drop to almost a stall on some starts. It is usually harder on very cold starts, but sometimes it will start fine cold and bounce the idle on a restart after a 10 minute drive.
I have gone through the Haynes, but before I get into that I am wondering if the dead alternator could have damaged the new battery? Of course a damaged battery would be the easiest fix, so I am hopefull. The Haynes refers to a few areas to cause this problem. I am thinking either a vacume problem, PCV, EGR, or sensor issue. This truck is all origional, with some hacking done by the previous owner, so anything is an option.
Any ideas would be appreciated.
Old Feb 7, 2009 | 01:39 PM
rob1981's Avatar
rob1981
Could be a lot of things , plugs fuel pump wrong size of battery. try full tune up first might be cheapest start
Old Feb 7, 2009 | 01:44 PM
SleeprLegend
I have been wanting a full tune up for a while. While I'm at it I will test some sensors and replace the VSS. She still has an exhaust leak I have to trace down.
Old Feb 7, 2009 | 06:52 PM
Freightrain's Avatar
Freightrain
IAC is a good place to start looking. It controls idle speed and if it's gummed up with carbon it will stick. Remove it, clean it and make sure the valve moves easily. If not, replace it. Very common idle issue.
Since you replaced the alternator, the battery should survive as long as you charged it up prior to using it again. The alt is not meant for full charging a dead battery.
Old Feb 9, 2009 | 08:08 PM
SleeprLegend
That is what I wondered about the battery. I will pick up a charger tomorrow and let her sit overnight. I have a feeling there is something up with anything that controls the idle due to the odd timing of the problem. This morning it started up fine. I drove 20 minutes and shut it off for 1 hour. When I started it back up it was bouncing the idle to the point where it almost stalled. A light press on the throttle seems to be all it takes to resolve the issue temporarialy.
Old Mar 5, 2009 | 10:13 PM
SleeprLegend
I found that my PCV valve had jumped out of it seat. As I pulled on it the plastic broke in the hose. I used a tiny screwdriver to remove the plastic in the hose, but slightly split the hose. I then put in a new PCV valve. Now it will bounce the idle at some times. This is only after a full warm-up and shut down. Now once I put it in gear the bouncing stops. If not it will stop as soon as the truck moves. I know the speed sensor is faulty, so I wonder if this might be a factor. A full tune up is set for the near future. I am going to do new oil filter, spark plugs, plug wires, cap & rotor. This should get me off to a good start. I know a new water pump is needed soon.
Old Mar 5, 2009 | 10:43 PM
HrdDrv's Avatar
HrdDrv
Have you taken off the intake hoses at the throtlle body and sprayed cleaner in there? It does get gummed up where fuel treatment doesen't reach.
Old Mar 5, 2009 | 10:53 PM
flamebuster's Avatar
flamebuster
have a similar problem on buds rig what is iac and where is it located. thanks in advance. doug.
Old Mar 6, 2009 | 09:15 PM
SleeprLegend
I plan to remove the throttle body and clean the whole thing. I plan on doing this when I clean out the IAC.
limpysmalls
21
Sep 7, 2013 03:44 PM
Rob400
Sep 13, 2011 02:07 AM
ceekay1
Electrical Systems/Wiring
Sep 7, 2004 01:07 PM
7scott
Apr 15, 2004 03:41 PM
poulin15
Jan 30, 2003 08:30 AM
