Found a Fuel Pressure Regulator
Old Feb 7, 2009 | 11:07 AM
KevinC.'s Avatar
KevinC.
I did a search and found this FPR because I am doing an electric conversion soon. It is adjustable from 0-100psi. Any thoughts on it or would you stick with aeromotive? Link: Megan Racing Fuel Pressure Regulator - Modern Automotive Performance
Old Feb 7, 2009 | 12:00 PM
Cuda_jim's Avatar
Cuda_jim
The one you posted is for a WRX....did they come with a diesel engine
It needs to be compatible with diesel fuel...most are not.
Old Feb 7, 2009 | 02:13 PM
c00nhunterjoe's Avatar
c00nhunterjoe
aeromotive is the only one i know of thats readily available with a good reputation, but they are around 150 bucks
Old Feb 7, 2009 | 04:28 PM
tjbeggs's Avatar
tjbeggs
I am gonna be using the aeromotive. Bought on ebay used and save a couple $ but not much. Even the one I bought isn't rated for diesel but many have used it. Its rater for alky and gas but not diesel. The actual diesel rated are even more $$$$
Old Feb 7, 2009 | 04:31 PM
tjbeggs's Avatar
tjbeggs
BTW when you do get a regulator don't use the boost signal for increase fuel pressure. Bad idea in case the diaphram starts to leak as you will have a runaway PSD!! Just put a line on that small nipple and run it out of the engine compartment.
Old Feb 8, 2009 | 07:39 AM
KevinC.'s Avatar
KevinC.
ooo ok. great advice. thank you guys
