Cab Clearance lights.
Old Feb 8, 2009 | 07:46 PM
  #31
86302f150's Avatar
86302f150
the only pair I found was at pull-a-part and on top of all the lenses being shattered the wiring was cut on it so I woulda been in splice city. As far as Pep Boys the closest one is an hour away and LMC has the complete assebly but its $$$$$ so my options are kinda limited
Old Feb 8, 2009 | 08:00 PM
  #32
Fordzilla80's Avatar
Fordzilla80
Man that sucks.There's a pep boys right down the road from me.Hope you can find a set.
Old Feb 9, 2009 | 05:50 AM
  #33
Sycostang67's Avatar
Sycostang67
It's just one large circular hole for the plug to pass through and then 2 small screw holes to hold the light assembly.
I got my harness and 3 lights off one truck and the other 2 lights from another truck. It seems as they get old and spending so much time in the sun that they begin to crack. The ones I got already have lots of little spider cracks, but I figure they will be something to start with and I can always get new ones later.
Old Feb 9, 2009 | 02:15 PM
  #34
srercrcr's Avatar
srercrcr
Spider cracks are common with age. Hail storms play hell with the lens too. As of a few years ago, the dealers carried the lens/light unit....pretty reasonable.
Old Feb 9, 2009 | 02:52 PM
  #35
81-F-150-Explorer's Avatar
81-F-150-Explorer
The lenses and gaskets as well as the complete unit is still avaliable.
And don't just limit yourself to F-150's.
Look at my original post on page one for interchangeabliity.
Old Feb 9, 2009 | 04:31 PM
  #36
Fordzilla80
I know.I'll be looking at any 80-96 F-series they got in the yard.They don't have any F700's,so i'm limited to F150-F350.
As for cracks,I'm like Sycostang,I can always get new ones later.
Old Feb 9, 2009 | 06:29 PM
  #37
73f100shortbed's Avatar
73f100shortbed
On my 73 they have all those cracks too and I thought about replacing them but you don't even notice them honestly especially when lit up.
Old Feb 16, 2009 | 06:14 PM
  #38
srercrcr's Avatar
srercrcr
I just remembered that when I ordered my 83 from the dealer the salesman couldn't believe I wanted Clearance Lights. He said, "You're gonna have the only half ton with clearance lights!" Flash forward...Truck with lights still truckin'....salesman long gone.
Old Feb 16, 2009 | 06:39 PM
  #39
86302f150's Avatar
86302f150
I got the OE replacements from Autozone, got em wired up, but I went to the right ( passenger ) side to look for that brown wire and couldnt find it... maybe its on the left?
Old Feb 16, 2009 | 06:43 PM
  #40
Fordzilla80
It's on the driver's side.Right behind the kick panel.It's kinda hard to miss.Hope you find it.I found mine,and will probably head out to the local yard this weekend for a center console lid for my new Ranger,and the clearance lights and harness for the F100.
Old Feb 16, 2009 | 07:00 PM
  #41
86302f150's Avatar
86302f150
I knew it would end up being the other side lol. It was just too damn cold out to pull the other panel off.
Old Feb 16, 2009 | 07:05 PM
  #42
Fordzilla80
Yep.lol.But it really doesn't matter since you got the aftermarket ones.It's not a direct plug and play like factory.lol.
Old Feb 16, 2009 | 07:07 PM
  #43
86302f150's Avatar
86302f150
yeah I had to wire them in series with 1 wire via open splices, tried pluggin em into the parking lamp fuse, turns out it has constant power Der, but they are bright as day. Dont even need headlights at night lol. I'll take that brown wire if it has a connector and cut the connector and spice into it
Old Feb 16, 2009 | 07:27 PM
  #44
Fordzilla80
Oh okay.Yea it's got a connector on it.But it's a small connector.
Old Feb 16, 2009 | 07:33 PM
  #45
86302f150's Avatar
86302f150
as long as I have enough to wrap the wire around a couple times and tape it im in grape shape.. I've worked with less before lol
my_crib_too
Dec 17, 2021 07:17 PM
Stevekron1
Oct 15, 2015 06:26 AM
MichaelTJD60
1997 - 2003 F150
Apr 19, 2015 10:45 PM
techningeer
Aug 7, 2014 06:31 PM
reamer
Apr 27, 2014 03:40 PM
