Sponsored by: Real Truck
Trailer marker/tail lights not working
Old Oct 14, 2015 | 07:31 PM
Stevekron1's Avatar
Stevekron1
I have an 05 F250. When connected to my travel trailer, my turn signals, brake lights and electric brakes work, but the clearance/marker lights and tail lights don't. I've checked the trailer clearance light fuses in both fuse panels and they're fine. No power at the outlet on the truck when tested with my meter. Anyone have any ideas as to what else could be wrong besides a broken wire somewhere? Am I missing a fuse or a relay that I don't know exist? I didn't check any relays because I didn't find any info on any for those lights. Any suggestions/input would be greatly appreciated!
Old Oct 15, 2015 | 02:31 AM
RV_Tech's Avatar
RV_Tech
Most often it is a connection issue at the seven pin on the truck. Check for power on the leads to the seven pin on the back side of it, that is behind your bumper. Corrosion is common on the back side.
Often you will find something that can look like this -
Old Oct 15, 2015 | 06:11 AM
Stevekron1's Avatar
Stevekron1
I tested it there too and no power.
Old Oct 15, 2015 | 06:26 AM
projectSHO89's Avatar
projectSHO89
See this thread: https://www.ford-trucks.com/forums/7...rk-lights.html including the additional thread linked to in post #2 in which several forum members including myself figured out the configuration of the circuit. You'll have to filter out the extraneous stuff that doesn't apply to the 04 and a bit newer Super Duty trucks.
Additional thread:
https://www.ford-trucks.com/forums/1...er-lights.html
funatic
1997 - 2003 F150
May 9, 2011 09:00 PM
myblkex
Jun 15, 2009 05:50 AM
phampton428
Jul 3, 2008 08:02 AM
Dave(TX)
1997 - 2003 F150
Aug 31, 2007 12:00 PM
rafman
All Things Towing
Jan 10, 2006 12:54 PM
