I Need help quick!
Old Feb 14, 2009 | 12:39 PM
dave2180's Avatar
dave2180
I Need help quick!
I just put a new distributor cap on my 1980 f150 351c 4bbl carter afb. Well I was not paying attention to where each plug wire goes. I went to start the truck and the new cap started smoking. Does anyone know which order the wires need to be re hooked up into the new cap? I need this truck to be running again by tonight any helpful posts will get rep points and lots of thank-yous. -Dave
Old Feb 14, 2009 | 12:41 PM
86302f150's Avatar
86302f150
the firing order for V-8 motors are 1-5-4-2-6-3-7-8... Believe me I've had my cap off more times than I've wanted so I have the firing order memorized
Old Feb 14, 2009 | 12:51 PM
dave2180's Avatar
dave2180
Are you sure because this is for a 351 Cleveland. [url]http://www.boxwrench.net/specs/ford_351C.htm claims the firing order is 1-3-7-2-6-5-4-8.
Old Feb 14, 2009 | 02:52 PM
86302f150's Avatar
86302f150
my manual says 1-5-4-2-6-3-7-8 but if the spec says otherwise you can try that firing order or this one
Old Feb 14, 2009 | 03:27 PM
rkymtnman30's Avatar
rkymtnman30
Are you sure it's a 351C? If so what did it come out of 1980 f-150 didn't offer 351C that I know of. 351M was common in the 1980 if that's what it is the timing order is 1-3-7-2-6-5-4-8 but if it has a 5.0 the firing order is 1-5-4-2-6-3-7-8
Old Feb 14, 2009 | 04:34 PM
86302f150's Avatar
86302f150
did they even make a carbed 5.0 tho? I thought they were all EFI's
Old Feb 14, 2009 | 04:44 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
A 5.0L is a 302cid.
One is a metric measure and the other is SAE.
They are the same engine.
Ford made 302's from circa 1965 to 1996, so yes lot's of them were carbed.
Old Feb 14, 2009 | 08:40 PM
bmuhlbach's Avatar
bmuhlbach
Ford quit the 351 Cleveland in 1974 and it never came from the factory in
a truck
5.0 or 302 where carbed till 85 some 85 where efi all most if not all 86's where efi
Old Feb 14, 2009 | 09:07 PM
86302f150's Avatar
86302f150
thats also when they changed the ignition system to the TEF IV or EEC
Old Feb 15, 2009 | 07:13 PM
dave2180's Avatar
dave2180
It is a 71' 5.8L 351c that I swapped in. I figured out the firing order though, it is 1-3-7-2-6-5-4-8. Thanks guys.
Old Feb 15, 2009 | 11:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Isn't it usually cast into the intake manifold?
Old Feb 16, 2009 | 12:09 AM
rkymtnman30
So, did you get it fixed then?
Old Feb 16, 2009 | 02:32 AM
ozstang65's Avatar
ozstang65
a truck
Depends where you live of course....
Old Feb 16, 2009 | 08:11 PM
dave2180's Avatar
dave2180
I got it fixed and she is running strong again, RkyMtnMan.
And ARDWRKNTRK, I dont know but if it does I'll feel like a DA.
