Trans temp sender
Old Feb 6, 2009 | 01:08 PM
74baja's Avatar
74baja
Trans temp sender
Hi all,
I am just finishing up my gauges, I'm installing the trans temp sender. Where does it go? I thought there was a well for it somewhere?
Thanks,
Jack
Old Feb 6, 2009 | 01:15 PM
jeff7825's Avatar
jeff7825
There is a plug just over the top of the transmission pan on the driver's side.
Here is a pic.....
Old Feb 6, 2009 | 01:16 PM
74baja's Avatar
74baja
Thanks.
Will any fluid pour out of there once I take the plug out?
Old Feb 6, 2009 | 01:21 PM
jeff7825's Avatar
jeff7825
If any does, it should only be very little.
Old Feb 7, 2009 | 01:36 AM
mongo75's Avatar
mongo75
you can always put ramps under the driver side wheels to keep fluid from coming out
Old Feb 7, 2009 | 01:45 AM
hucka1a's Avatar
hucka1a
It's great to see ya posting Danny. Stay safe bro.
over.
Old Feb 7, 2009 | 01:56 AM
mongo75's Avatar
mongo75
Thanks Huck, glad to be here!
Old Feb 7, 2009 | 09:34 AM
Ponyboychris's Avatar
Ponyboychris
Originally Posted by 74baja
Thanks.
I had a drop but didn't waste much time swapping the pipe plug for the sensor. I did put the pipe plug in the glove box just in case anything should happen with the sensor either leaking or breaking on the road. I'm just that way.
Old Feb 7, 2009 | 09:35 PM
Dieselmanor's Avatar
Dieselmanor
FTE Sponsor
If you're installing a set of gauges, here's the link to the full instructions:
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
and this
The location for Tans. Sender on a 7.3L 4R100 Transmission can be found just above the 2nd trans. pan bolt on the driver's side. There is a test port plug here (arrow). Remove it and insert the trans. sender. No need to worry about excessive fluid loss. Only a few drops will come out if the truck is level. Image shown with an 11mm wrench in the plug.
Old Feb 7, 2009 | 10:02 PM
Steve_250's Avatar
Steve_250
Soak the bolt with your favorite loosening agent before you try to twist on it....
And it is never as easy as the pic shows, don't remember what it is, but I have something blocking straight-on access to the bolt.
Old Feb 7, 2009 | 10:21 PM
74baja's Avatar
74baja
Hey guys,
Thanks, I got it. Now I just need to figure out which wire goes where. I guess I didn't mark them well enough. Is there any way to tell without hooking them up which wire does what? I don't want to accidently wire them backwards and blow them up.
Thanks
Old Feb 8, 2009 | 10:45 AM
Ponyboychris
Hey guys,
Thanks
What brand of gauges do you have? My autometers are marked on the back of the gauge as S for sensor wire, I for ignition (key on hot) and a ground marked with G. The light is a direct wire to the bulb socket.
WEagle
Mar 18, 2017 05:54 PM
justcruzin125
Sep 7, 2016 01:06 PM
zenish
Aerostar
Apr 27, 2016 03:40 PM
Crewcabber
Sep 8, 2015 07:11 PM
286merc
Oct 28, 2002 07:41 AM
