Horn
Old Feb 6, 2009 | 04:59 PM
76F100guy's Avatar
76F100guy
Originally Posted by 81-F-150-Explorer
Not exactly, the horn brush is a part of the turn signal switch, and has to be replaced with the entire turn signal switch.
So if his horn brush is bad, he has to replace the entire D3TZ-13341-A (manual) or D3TZ-13341-B (Auto) turn signal switch.
EDIT: Picture...
This is great, too. I'm hoping it's cheaper than replacing the switch assy. Thanks for the P/Ns!
Old Feb 6, 2009 | 05:45 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by 76F100guy
...hoping it's cheaper than replacing the switch assy.
Don't know if it'll work, but first thing comes to my mind is getting a brush
from my collection and modifying it so it'll fit and work. A new brush from
Ace Hardware is a second choice and might still need modifying tho.
I'm a pack-rat and I squeak when I walk. :/
Alvin in AZ
Old Feb 6, 2009 | 06:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There is no separate horn brush listed after 1970 for an F100/350, so it cannot be replaced by itself.
For a 1976 F100, there are three turn signal switches, not two.
D3TZ13341A .. M/T 1973/77
D3TZ13341B .. A/T 1973/77
D5TZ13341B .. Use with Cruise Control 1975/77.
Prior to 1971: The steering wheel has a hole where the separate horn brush and plastic insulator (C2OZ13A821A-sold as a kit) fits into.
The brush is about 1" long, and is composed of a copper tube connected to its base by a thin wire and a coil spring, similar to what a ball point pen uses.
Old Feb 6, 2009 | 07:47 PM
AerostarDad's Avatar
AerostarDad
Could also be the corresponding horn contact area on the back of the steering wheel?...the circular part on the back of the steering wheel that the "horn brush" contacts?
Old Feb 6, 2009 | 07:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Thanks for the information on the additional turn signal switch for cruise, Bill, forgot that one.
Yes it sucks having to replace the turn signal switch for a horn brush, but you do.
However, we still don't know if this is his problem yet. It's only a potential or possible cause for the problem at the moment.
Old Feb 6, 2009 | 07:54 PM
81-F-150-Explorer
Very true, and that would require replacing the steering wheel.
Velocity2
Nov 27, 2014 02:49 PM
Duckmang
Jul 28, 2013 11:40 PM
F350moneypit
19
Feb 4, 2013 01:46 AM
chesire17201
Jan 2, 2012 08:15 AM
daggerNC
18
Nov 7, 2004 07:28 PM
