Warm resistor wire
Old Feb 4, 2009 | 06:16 PM
F250GH's Avatar
F250GH
Warm resistor wire
Chasing electrical gremlins and found the resistor wire at ignition switch to become warm when key is on. Normal?
Old Feb 4, 2009 | 06:25 PM
Orange '63's Avatar
Orange '63
It's normal, but what ignition components are you using - original coil and points, or something newer. Newer coils and electronic ignitions should not be used with the resistor wire. They need a full 12 volts.
Old Feb 4, 2009 | 07:55 PM
F250GH's Avatar
F250GH
Using all original components. Coil, distributor, points, alt, and solid state volt reg.
Old Feb 4, 2009 | 08:54 PM
Orange '63's Avatar
Orange '63
Then it's normal. If you bought a new coil though, make sure to double check that it's an external resistance coil.
Old Feb 4, 2009 | 09:58 PM
F250GH's Avatar
F250GH
The old coil has been repainted many times over, so there is nothing to be read from it. Seeing the voltage drops from 12 to 6 vlts, when coil is connected, it must have an internal resistor. ???
Old Feb 4, 2009 | 11:00 PM
Orange '63's Avatar
Orange '63
Well no, not really. The voltage drop should be on the lead wire itself, not on the coil, though the coil does draw voltage when the points are closed. Try opening the points and see if the voltage goes up a bit. Anyway, the pink wire should feel warm, but not hot. If it feels real hot, the coil might be bad. Look carefully at the old coil. It should not be misshapen or have any irregular dents or bulges in it.
Old Feb 5, 2009 | 11:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1960/73 all cars/trucks: COLF12250A .. Resistor Wire-Ignition Coil (Motorcraft DY37).
61.49" long // 1.30/1.40 ohms resistance // Color code Pink // #20 gauge wire.
What's this?
1974/87 all cars/trucks w/ DURASPARK: D7AZ12250A .. Resistor Wire-Ignition Coil (Motorcraft DY213).
49" long // 1.30/1.40 ohms resistance // Color coded red with green stripes // #16 gauge wire.
Old Feb 5, 2009 | 05:08 PM
Orange '63's Avatar
Orange '63
NumberDummy wrote "1974/87 all cars/trucks w/ DURASPARK: D7AZ12250A .. Resistor Wire-Ignition Coil (Motorcraft DY213 )"
I didn't know that. II've got a pertronix kit in my truck and it called for eliminating the resistor wire. Runs much better.
Old Feb 5, 2009 | 07:46 PM
drof46's Avatar
drof46
Hmmm interesting. I will be running a different engine in my 66. I bought a Mallory HEI unit with distributor and coil both together. Better do some checking before I hook it up so I don't start my truck on fire.
