Another 6637 Question
Old Feb 4, 2009 | 08:24 PM
Jbrown8988's Avatar
Jbrown8988
yea i hate walmart. i park in the tire lube express and run in and out! sorry off topic.
Old Feb 4, 2009 | 08:26 PM
riverrat41's Avatar
riverrat41
Originally Posted by F350-6
I've never seen anything like that at wally world, but then again, I tend to put my blinders on, head straight for what I need, and get out. Can you get us a part number by chance so we can look into this?
I found the Fram part numbers and other brands of the same filter.I have them at work though!
Old Feb 4, 2009 | 08:33 PM
Jbrown8988's Avatar
Jbrown8988
Fram, ca6818
Old Feb 4, 2009 | 08:38 PM
F350-6's Avatar
F350-6
Originally Posted by Jbrown8988
Fram, ca6818
I just found that too, but so far it doesn't appear to be any cheaper online than the wix filter. I might have to pay a little more attention next time I'm in walmart.
Old Feb 4, 2009 | 08:43 PM
Jbrown8988's Avatar
Jbrown8988
RockAuto Parts Catalog
i'm on the phone with walmart right now! haha
Old Feb 4, 2009 | 08:48 PM
riverrat41's Avatar
riverrat41
Chris...I will e-mail you those numbers tomorrow.I have been buying fuel/oil filters from a fella in Crowley for several years now.
Old Feb 4, 2009 | 08:51 PM
Jbrown8988's Avatar
Jbrown8988
18.84 at walmart
Old Feb 4, 2009 | 08:52 PM
Jbrown8988's Avatar
Jbrown8988
https://www.ford-trucks.com/forums/5...reference.html
Old Feb 6, 2009 | 11:01 AM
mxracer3276's Avatar
mxracer3276
Instead of using 4 inch exhaust pipe when doing this mod, can i just use PVC pipe? Is it going to make much of a difference?
Old Feb 6, 2009 | 11:26 AM
brian42's Avatar
brian42
Veteran: Navy
Yes you can use PVC. The only difference is that if you gronk the hose clamp too much the PVC might crack over time. The heat should not be an issue, but will also make the PVC more brittle over time whereas the exhaust pipe will last forever.
I spent a little more and bought a 4" piece of polished aluminum intake piping for mine when I bought my filter at my local Napa because I had to have it NOW and couldn't wait to get one shipped (when the wife gives you time to work on the truck, you get the parts and git-r-done when you can, even if you spend a few extra bucks).
Old Feb 6, 2009 | 06:25 PM
F350-6's Avatar
F350-6
No, you don't want to use PVC pipe. You need a 4" OD. You can use a 3" PVC coupler, which has a 4" OD, to make your connection. Many people here have done that. The good side is you don't have to buy a whole piece of pipe. The length of the coupler is long enough.
Old Feb 9, 2009 | 09:48 AM
superduty4x4's Avatar
superduty4x4
What he said. Trouble is, the coupler is thicker walled than 4" exhaust tubing so it chokes down the intake a bit. I have ABS couplers in there now, going to replace them sometime (soon I hope... as soon as the wife quits finding projects in the house for me to do) with 4" exhaust.
Mowing Man
54
Nov 27, 2021 05:45 PM
kbarbee95
20
Aug 6, 2015 05:28 PM
Kevinr92
40
Sep 4, 2014 08:49 AM
OldWoodsDiesel
Dec 21, 2012 08:42 AM
nrskel78
Oct 26, 2009 01:15 AM
