AD Injectors
Old Feb 4, 2009 | 07:49 AM
blake 7.3L's Avatar
blake 7.3L
AD Injectors
I have a set of AD injectors out of a superduty, well one is an AE (#8 I think). I have few questions about them:
1. Is it benefical to run these in our trucks?
2. Do I need to find another AD to replace the AE?
3. What kind of performance gain would I be looking at?
4. Or would I just be wasting my time and sould just wait til I can get some stage 2's through Jim?
Thanks guys!
P.S. I know that I would have to get my chip reburnt.
Old Feb 4, 2009 | 09:38 AM
Brown Falcon's Avatar
Brown Falcon
You would need to swap in a ECU from a superduty to run the injectors... you'd get more power, not sure how much
that's all i know...
Old Feb 4, 2009 | 09:39 AM
MADVAN's Avatar
MADVAN
If your 97 is a cali you can toss them in.
You will make some power with them in the bottom
and mid range. You could suffer on the top with tunes
from an over taxed HPOP.
Bill
Old Feb 4, 2009 | 10:30 AM
blake 7.3L's Avatar
blake 7.3L
It is not a cali truck but if I have my TW chip tuned for them I thhink it would be fine. I also have a 17* pump which is what pushes them stoke so that should be fine too. Do you see any other issues and do I need to replace the AE injector?
Old Feb 4, 2009 | 10:52 AM
superduty4x4's Avatar
superduty4x4
Get rid of the AE for sure. 17* pump will run them fine, but can still fall flat up top with tunes.
Old Feb 4, 2009 | 11:21 AM
tjbeggs's Avatar
tjbeggs
As long as the AD are free and you have a 17degree HPOP your good. have tony burn your chip for them and your good to go. Thats what I am running.
Old Feb 4, 2009 | 11:33 AM
blake 7.3L's Avatar
blake 7.3L
They are but I will have to buy an AD to replace the AE. Did you replace the AE? How do you like yours?
superduty4x4
You don't want the AE... trust me on this.
Old Feb 4, 2009 | 11:59 AM
MADVAN's Avatar
MADVAN
HaHa
Send the AE to Me!
Bill
Old Feb 4, 2009 | 07:47 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I don't know if you would have to get rid of the AE or not. AFAIK the only difference between AD and AE is the solenoid pack. Which, I think, keeps it open just a bit longer.
Mine ran 144,000 miles with a stock AE and never gave me any problems.
Old Feb 4, 2009 | 08:21 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Why?
The only difference between them is that the Intensifier Piston is about .004" shorter on the AE, equal to about 3 cc more, not a big deal unless you're really picky about having your injectors flow matched.
I have seen sets of Pistons off by as much as .008" from longest to shortest in a set of 8 injectors, so I really don't see how that little bit would affect you.
I'm sure it does, but that small amount, IMO isn't worth worrying about. Throw it in and forget about it...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Feb 5, 2009 | 09:55 AM
superduty4x4
Originally Posted by DZL JIM
Why?
All the SD guys complain about the AE #8 and want to get rid of it... but you know WAY more than I ever will about this stuff so I'll take your word
Old Feb 5, 2009 | 10:19 AM
tjbeggs's Avatar
tjbeggs
I would say they complain more about the reason for the injector being in there than the injector itself
Old Feb 5, 2009 | 10:58 AM
superduty4x4
Good point Tim.
Old Feb 5, 2009 | 11:08 AM
MADVAN's Avatar
MADVAN
X2
Deadheaded Fuel was a big mistake.
Tj
I have installed AE's as sets of 8.
I must have it mixed up with just cyl #8.
Bill
