HPX crossover
Old Feb 4, 2009 | 07:37 PM
  #31
High Intentions's Avatar
High Intentions
Mod Specialist ;)
Thanks guys.....What does WOT mean???
Old Feb 4, 2009 | 07:38 PM
  #32
CSIPSD's Avatar
CSIPSD
Wide Open Throttle...
Old Feb 4, 2009 | 08:51 PM
  #33
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by Izzy351
That's the first I've heard of that one -- I know it will equalize the two heads, and it definitely helped mine at idle. AFAIK, the #8 issue is a fuel problem, not a HP oil problem. But at WOT, it will also equalize HP oil pressure in the heads I guess, so who knows...
#6 injector fires just before # 8. #6 takes the PSI from the #8 because the oil rail is only pumping to each head. With the HPX, it lets the oil from the HPOP flow through the HPX line from the other head and lets the #8 get the right psi to fire. This is what I thought. I can see this.
Old Feb 4, 2009 | 09:13 PM
  #34
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Well, I WOULD do it again. I put the SS HPX on from ITP Diesel, and it got a little quieter, but the engine smoothed out quite a bit. When it was stock it would bounce around in the engine bay at idle, and now it barely wiggles at all. Good mod in my book, and only a minor inconvenience when pulling the turbo.
My $0.02...
Me too. Mine idled out smoother about a hundred miles after installing. That was the first one that I installed, and it was a DI braided line. I ran that for a year and then replaced it with a hard line. No leaks from the braided line and it's in great shape. I just wanted a hard one. I've bought a lot of stuff from DI and have never had a problem with their products or customer service. David is a great guy.
Just my .02, just like Joe.
Old Feb 4, 2009 | 09:15 PM
  #35
a-rod's Avatar
a-rod
I have the rubber one from PDP (pure diesel power) had it for about 6 months now. Its high pressure hydralic hose. I thought it smoothed out my motor some, not a huge difference but worth 45 bucks.
Old Feb 5, 2009 | 05:57 AM
  #36
Powerstrokedlariat's Avatar
Powerstrokedlariat
Originally Posted by zx250
Guess I will go with the minority here and say yes, I would do it again. I didn't see a major difference, but there was a difference for sure. Quieter idles, less knock. My wife even noted that on her first trip with it installed. I used the solid SS one from KCM and for the $45.00 buck I paid 3 years ago. Never a leak although I did replace the orings when I replaced the rest of the orings. I would steer clear of the flexible ones as many have had problems with them.
Thats what I am running, (KCM) and it's been on for over a year now without problems. I noticed the smoother idle, and would do it again. I keep the plugs in the truck along with the wrenches in case.
Old Feb 5, 2009 | 07:37 AM
  #37
Izzy351's Avatar
Izzy351
That's exactly right, but the issue was not the oil that I've ever heard -- it was fuel because of the dead-ended feed system. I understand the concept of what you're saying but the fix for the fuel situation is the RR or CCK (I have the CCK). If that's what the HPX does, I'm surprised I haven't heard that before. Besides, the fix for the HPOP petering out is to get a big (or medium) oil system, or go with SS/Hybrid injectors. They require less oil to fire, and inject more fuel with it.
Next for me is to put on the fuel pressure gauge like Brandon's and shimming the FPR after I put in the Walbro pump. That will provide PLENTY of fuel volume, even with larger injectors that will follow.
Old Feb 5, 2009 | 07:55 AM
  #38
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
agreed^^^
the problem with #8 wasnt getting enough oil but not getting enough fuel...
i like my ITP hp x-over and would do it again and i dont have to take it out to get my turbo out. the itp hard line has a "dip" in it and you can pull your turbo out right through the "dip". atleast a stock one you can. joe is probably running something a tiny bit bigger. jmo.......
Old Feb 5, 2009 | 08:08 AM
  #39
miller_feed
Originally Posted by indyF-350psd
agreed^^^
The CCK if for the fuel, the HPX is for the oil. The HPX is taped into the oil rail of the heads. I guess both would help. Thats what I thought anyway.
Old Feb 5, 2009 | 08:58 AM
  #40
CSIPSD's Avatar
CSIPSD
LOL... There is no issue with #8 not having oil... The X over will do nothing but even the pressure spikes a little.
Old Feb 5, 2009 | 09:23 AM
  #41
miller_feed
Well Hell, I guess I put the HPX on for the wrong reasons. . I sure thought it was for the oil.
Old Feb 5, 2009 | 09:54 AM
  #42
strokersace's Avatar
strokersace
I'm still thinking like Rick here.
As Izzy has said, it's a fuel thing on the #8. But isn't our fuel system ran by the oil provided in the rail? And as Joe said, the HPX equals out the pressure spikes between the heads giving way to a better pressurized oil rail per head because they are tied together. The #8 is also the furthest away from the HPOP hose going into the head. Not by much, but it's at the end. It's also at the end of the "deadend" fuel rail. Combine the 2 together, and then it's not performing like it could or should and struggling to keep up. By installing a HPX, you're getting better oil pressure to the back of the head so the injector can fire properly. Yes the deadend fuel rail is still present on a stock system, but a little more oil is there for the injector.
Granted, I'm NO expert and could be completely wrong!! Just going off of information I've read and heard.
That's my $.04 (I got a raise)
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
