blown automatic tranny
Old Feb 9, 2009 | 01:06 PM
  #31
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Honestly, I have both a 6.0 cooler and a Mag-hytec pan-w/a guage stabbed into it. Two gauges for the trans one in the test port and pan. I have no heating issues at all.
Dave, just wanted to get your opinion.
Old Feb 9, 2009 | 02:34 PM
  #32
SpringerPop's Avatar
SpringerPop
Originally Posted by dave at BD Power
I am not disagreeing with that, a tranny cooler will do a much better job! I am disputing that the pans will not do anything.
The pans will also add rigidity to the casing...
OK, "anything" is an absolute term. All "absolutes" are false, as there's always an exception somewhere. So yes, fins will make a "difference", albeit ALMOST nil. There's a case to be made, too, for touting that deeper pans, without fins, will dissipate more heat due only to the greater surface area. But nobody does, unless they're selling deeper pans without fins.
When my money's spent for additional cooling (and then, only if I actually need it) it won't be on a "finned tranny pan".
Added case rigidity? I suppose, but I suspect if Ford had a big problem with cases flexing under "normal" circumstances, they would have cast a more stout case. Saaaay.... There's a business opportunity! Supply a new, more rigid, casting for those making mega-power.
Pop
(At my age, MUCH more interested in
reliability than making big horsepower)
Old Feb 9, 2009 | 02:45 PM
  #33
dave at BD Power's Avatar
dave at BD Power
Former Vendor
Pop
Its great that you have a lot of confidence that Ford would upgrade poorly designed parts the first time... a lot more than I do!
Thanks for your comments, I am sure someone will appreciate them, but I got better things to do than split hairs on cooling fins...
Dave
Old Feb 9, 2009 | 05:00 PM
  #34
CampSpringsJohn's Avatar
CampSpringsJohn
Not that it matters, but I broke 3 bellhousings out of a GMC 3500hd before I figured out the problem. It was with the 4L80E tranny, and with new motor mounts and tranny mounts, I managed to break 3 of them before I figured it out. Turning on to my road, the road goes up at a sharp angle, and I was always in the turn. It would twist the truck in a bad way. I would hear a popping noise and could never figure it out until on the 3rd tranny. That was an expensive lesson.
Old Feb 9, 2009 | 05:04 PM
  #35
dave at BD Power
Former Vendor
It does matter... your feed back is appreciated, it can be an issue like it was for you! If only one person can relate to your comments then it was not for nothing!
Thanks!
Old Feb 9, 2009 | 07:16 PM
  #36
SpringerPop
So, is case-cracking a problem for 4R100's in SuperDuty's, especially at the power levels most of our members turn out??
Seems we would have heard a little something about it around here over the past few years, and some of our members make considerable power. There are usually other internals that'll snap first, and we know about the fixes for them.
Remember, most of us guys aren't exactly the thousand-horsepower, sled-pulling crowd.
When I start hearing of a lot of problems with cracked or distorted cases, when towing appropriate loads, I'll rethink my position about adding a finned aluminum tranny pan.
Until then, it just seems like bling.
Of course, that's not bad, if you're into that sorta' thing.....
Pop
