help pls!!!
Old Feb 2, 2009 | 09:31 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
help pls!!!
my truck has been acting up lately when first starting like runnin real rough for a while like its gonna shake itself apart but now its like that the whole time i drive i first get in it will start fine and run fine until i go to take off then it bogs down real bad and wants to die and i cant get going very fast - could it be map sensor
Old Feb 2, 2009 | 09:34 PM
jimwilsonmasonry
and my oil gauge will drop all the down and come back up real fast and it slows down and accelerates wildly and i can hear like a bom bom bom bom from the air intake filter
Old Feb 2, 2009 | 09:35 PM
strokin'_tatsch's Avatar
strokin'_tatsch
is it blowing smoke? does it set the CEL? is the exhaust backpressure valve sticking closed? unplug it just to check. if it has the CEL check the codes, if not is it only doing it cold or even after the engine is warm? check the HPOP res. as well. check the oil, fuel filter, and fuel pressure.. maybe try a CPS? just some stuff to check on.. hope this helps
Old Feb 2, 2009 | 09:39 PM
strokin'_tatsch
oh yeah and unplug the chip and see what happens.. maybe unplug the map sensor and see if it changes. if it doesn't then unplug the ICP sensor and see if it changes. sounds like your running out of oil possibly though.. definitely check your oil level in the pan and the HPOP res!!!!!
Old Feb 2, 2009 | 09:41 PM
c00nhunterjoe's Avatar
c00nhunterjoe
oil gauge may be dropping due to extrem low rpm, can you pull codes? if not you can try the map sensor trick, but violently shaking sounds a little different. perhaps a burnt valve cover harness? but the popping from the intake sounds more like a bent pushrod, that kind of fits the basic description you gave.
codes would be a great start, then go fo rthe visual inspections
Old Feb 2, 2009 | 09:43 PM
jimwilsonmasonry
it does set a cel but goes off after i shut it down it was only doing it cold but know its doin it the whole time
Old Feb 2, 2009 | 09:44 PM
jimwilsonmasonry
every now and then for a little bit it will run good as new
Old Feb 2, 2009 | 09:47 PM
strokin'_tatsch
that's very strange... maybe the fuel heater could have come loose and is arcing to the side of the fuel bowl, but i'm not sure what that would do, but i do know it can come loose and short out. just dont remember what it does. if you can scan it for codes or get it scanned that would be a good start. it could have saved a code that may lead to your problem?
Old Feb 3, 2009 | 09:46 AM
Neal 97 250's Avatar
Neal 97 250
I would put money on the EBPV. Unplug it and wire it open.
Old Feb 3, 2009 | 09:54 AM
MADVAN's Avatar
MADVAN
Pull the codes.
Bill
Old Feb 3, 2009 | 06:05 PM
jimwilsonmasonry
i unhooked my ebpv a long time ago- i leak a lot of oil when its cold and its about single digits here i just checked my oil and it is extremely low but im broke i have it parked of course but will being really low on oil and extremely cold cause this
Old Feb 3, 2009 | 06:06 PM
jimwilsonmasonry
i usually have to throw a couple quarts of oil in it a week when its cold out
Old Feb 3, 2009 | 08:12 PM
strokin'_tatsch
have you figured out where the leak is coming from?
Old Feb 3, 2009 | 08:20 PM
jimwilsonmasonry
its comin from a line on the driver side front of the engine
Old Feb 3, 2009 | 08:31 PM
c00nhunterjoe
first problem is low oil, can cause all kinds of drivability issues and an eventual no-start. the leaking line is probably a high pressure line, the cold soak is probably allowing air tin the system and the cold start is showing the air.
