5.8 head job
Old Feb 5, 2009 | 10:47 PM
Beanscoot's Avatar
Beanscoot
The problem with the "P" heads is that the spark plug angle was changed, complicating header or manifold installation.
Old Feb 7, 2009 | 02:45 PM
Beamed's Avatar
Beamed
will windsor headers work with the gt40 heads and how much of a diffrence will these make
Old Feb 7, 2009 | 10:34 PM
Sportruk's Avatar
Sportruk
The GT40's are what is used on the Gen I Lightning. Probably good for about 15 HP over the E7. Just a guess.
Old Feb 7, 2009 | 10:39 PM
Beamed's Avatar
Beamed
what about the exhust tube headers would they be the same and the stock 351s
Old Feb 8, 2009 | 01:15 AM
Sportruk's Avatar
Sportruk
Yes, the Lightning tube headers are the same configuration as the stock castiron manifold on the 351. Same as any truck shorty header.
The GT40 head is identical to the E7 head, just better flow numbers.
Old Feb 8, 2009 | 12:28 PM
Beamed's Avatar
Beamed
what ford vehicles come with the gt40 heads ill go get me a set for 80$ today from the junkyard thanks
Old Feb 8, 2009 | 12:47 PM
Conanski's Avatar
Conanski
The Gen1 Lightning, '96-97 Explorer 5.0, and Mustang Cobra. Look for 3 vertical bars on the end of the head and the following casting numbers...
Old Feb 8, 2009 | 01:00 PM
Beamed's Avatar
Beamed
is there anything i should look for to find a nice set off a motor, ill try to find the lowest millage motor. i wish there was a gen 1 lighting in the junk yard, it would be in my yard. heres a page with sb ford flow numbers Board Navigation
some good info for ya guys
Old Feb 8, 2009 | 03:44 PM
Beamed's Avatar
Beamed
thanks and conanski what about usin the gt intake manifold is there any power gains using that setup and would it work on my truck
Old Feb 8, 2009 | 03:46 PM
Beamed's Avatar
Beamed
also what about the 85 - 86 heads would they give me any more power gains than the gt40s, would they work on my truck and is changing the heads even worth doing
Old Feb 8, 2009 | 05:18 PM
Conanski's Avatar
Conanski
The GT intake may flow a little better than the stock 5.8 truck intake but you'll need a 5.8 GT lower to use it, the 5.0 lower is too narrow. The 5.8 certainly will benefit from better heads, and the GT40's are better than anything that came before.. in stock unported condition.
Old Mar 29, 2009 | 03:16 AM
laynejc's Avatar
laynejc
so what is better in ported condition?
Old Mar 29, 2009 | 11:05 AM
  #28
Conanski's Avatar
Conanski
That's impossible to say because it depends how competent the porter is and exactly what is done to the heads. The old C9 casting has a lot of potential but it doesn't make much sense to spend $1500+ to have somebody professionally port them when you can buy brand new heads that will outflow them for less.
'89F2urd
20
Nov 5, 2011 10:31 AM
E30tdf
Nov 14, 2009 09:47 AM
fomocoguy3
21
Dec 11, 2007 08:23 PM
backwoodspuller
Oct 12, 2006 10:06 PM
Sixoh
Nov 23, 2004 10:47 AM
